New ways of keepin it real cool
Old 01-12-16, 07:03 PM
Justind27
Justind27's Avatar
Thank you all very much! I'm super stoked to move on with more and more mods and track events!
Bigjon- yes! I still want to appear street legal for the most part and be able to cruise across state to race (my bro drives the diesel e350 to haul stuff I drive just because). Cars getting lots of tweaks this week, just got more fittings to hopefully finish the engine cooler, till the thermostat arrives and the trans cooler
Old 01-13-16, 05:01 PM
nikogio38
nikogio38's Avatar
Cost? What did you gain?
Old 01-13-16, 07:25 PM
Justind27
Justind27's Avatar
.6 more quarts of trans fluid in a bigger cooler, new hoses and fittings, lighter weight bracket. Overall I'm not sure yet, not done with all the fitment versions.
Also, the additional 25 row air to fluid oil heat changer plumbed into the oem filter housing, holds over a quart with lines.
The skid plate is easier to work with and more durable than the plastic fairing
Here soon the radiator will be done so I'm not sure a oh engine temps yet, I'm going to be adding sensors for some defi gauges on everything.
Old 01-13-16, 08:22 PM
nikogio38
nikogio38's Avatar
**** is sick though it's good to see some real moding orther intake headers exhaust **** get old...
Old 01-14-16, 01:36 PM
Rickna
Rickna's Avatar
Woah! Very innovative, I like your fabrication skills.
Old 01-14-16, 03:25 PM
Justind27
Justind27's Avatar
Thank you! I don't weld aluminum, yet.. My fab guy did that, I bent, drilled, cut and test fit everything! His biz is called "just weld it" he welded together these Ferrari dealership automated stands and endless amounts of contracts with metals ranging from none- automosphericly welded titanium, stainless, aluminum.. He's good, his was a quick drop by on Friday before we both left town
Old 01-14-16, 03:45 PM
Rickna
Rickna's Avatar
Very nice & clean on the welding. I did some fab work before I got hurt. I do miss it.
Old 01-14-16, 04:47 PM
nikogio38
nikogio38's Avatar
Going drop any weight on the isf?
Old 01-15-16, 02:47 AM
Justind27
Justind27's Avatar
Here's one thread with some info (https://www.clublexus.com/forums/is-...-weigh-in.html) the other is by slayx "weight reduction", my previous race weight (only 1/4 tank In the car) was about 3600 on the dot. I want to reduce things more though, I have changed quite a few things since the previous weigh in but she's still right approx 3625 (calc'd the approx same fuel as before)
Old 01-29-16, 05:07 AM
Justind27
Justind27's Avatar
Here's my latest update:
Dual mishimoto le gold coolers, they will fit like a pair of oem coolers and 90 degree fittings are first installed to the filter housing then the line fitting needs to be changed to a straight and routed around the core unlike the previous design of the engine lines going under this will be safer for us lowered guys and the airguide won't have to be trimmed, I'm leaving the bigger surface area cooler on the engine side of things since it was already used in the process..
w9kcj
10-08-17 06:38 PM
wanganstyl
SC400 / 300 Classifieds
06-11-10 01:38 AM
ILOVEGIRLS
Performance
06-04-04 03:51 PM
Colby
05-22-04 01:20 PM
1BadAzzLex
01-27-03 03:41 PM
Quick Reply: New ways of keepin it real cool
