Michelin PSS on OEM size
Old 04-25-16, 12:46 PM
  #136
mindcrime
mindcrime's Avatar
Originally Posted by SubOrbital
Conversely, I might mention that those wanting more sidewall and more tread could downsize to 18" diameter tires. A 255/40/18 in the front and 285/35/18 in the rear are nearly identical diameters to stock.
then you would need to buy 18inch wheels. ain't nobody got extra money for that. at least not me.
Old 04-25-16, 12:48 PM
  #137
SubOrbital
SubOrbital's Avatar
And that's the position I'm in.
I realize this thread seems to be about OEM wheels, but I figured it's worth mentioning.
Old 04-25-16, 03:23 PM
  #138
F_Throttle
F_Throttle's Avatar
What alignment are people using with 245/275?
Old 04-25-16, 05:18 PM
  #139
mikersoft
mikersoft's Avatar
Not really. 255 in the front is best (that's what I am running), and if you run Bridgestone, run 285s in the rear. If you run Michelin, the best you'll get is 275.
I second that. I just did a track day last Friday.. I love the 255 PSS up front!
-Mike
Old 04-26-16, 04:51 AM
  #140
Piciu
Piciu's Avatar
Do you have OEM suspension and alignment? Any special camber adjustment?
After my first track day my front tires were quite destroyed (outside edges) - how did it work for you?
Old 04-26-16, 09:28 AM
  #141
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,969 Likes on 2,403 Posts
I watched your video. You pushed the car too hard in the corners and scuffed off a lot of rubber because of it. When you can hear the tires complaining the way yours were, you need to look at what you are doing, not what the car is doing.
I have run at the track with OEM shocks, springs, and alignment and not done to my tires what you did to yours. If you want to see pictures of my tires after a track weekend, take a look a Reconsidering the Factory Alignment.
Old 04-26-16, 01:55 PM
  #142
Piciu
Piciu's Avatar
Well, I'm learning the car and I was pushing it of course, but speeds in the corners were poor, comparable to my old e90 330i, which is very disappointing for competitor to M3...
I'm doing alignment soon, putting PSS and on top I will experiment with pressure - hopefully I can test it on the same track soon with better result.
Old 04-26-16, 03:42 PM
  #143
mikersoft
mikersoft's Avatar
Yes, I still have OEM suspension, with the exception of FIGS front LCA bushings. I believe my alignment is to Lexus' specs, but I'm not 100% sure (I didn't ask for any particular settings).. I can look for the print out with specs.
Here's my left front tire, which took the majority of abuse at the last track day. I've had these tires since late August of last year, and they've gone through two track days (though, 2 of the 8 total sessions were in the rain)
-Mike
Old 04-27-16, 01:17 AM
  #144
Piciu
Piciu's Avatar
Thanks for posting it. It looks still quite fresh.
Could you please tell me what cold/hot pressure you are using?
Old 01-04-17, 02:15 PM
  #145
Lextasy4
Lextasy4's Avatar
Originally Posted by Jz39
I went with the 265/35 and 235/40 set up in PSS and even though the theoretical numbers are only slightly greater diameter than stock, I must admit that I prefer the look of the wrapped front OEM size vs the 235-the 235 bulges just a bit compared to stock, but even that slight sidewall increase IMO does not look as good as stock.
I'm honestly thinking about biting the bullet and replacing the fronts to OEM size. Anyone want to buy 235/40 PSS fronts with ~300 miles on them?
The 265 Porsche OEM rear I have no problems with at all. It looks perfect, perhaps even better than OEM because it closes the wheel well gap a bit.
This set up does handle quite well, no issues there, and it has two positive attributes, one of them unexpected: 1) ride quality is a bit smoother, 2) the extra 0.3" actually allows the front of my car to safely clear the bottom step in my garage, something I couldn't do with the OEM PSS!
If I had to do it all over with the 2011 rims I would probably just go with stock size front and rear. Just my opinion.
Do you have a picture of the 235/40/19 on the car? I am going back and forth with myself on what to get. I had wheels on my IS350 that I transferred to the ISF when I traded. The specs are:
Front: 19x8 +40 offset 235/35/19
Rear: 19x9.5 +40 offset 275/35/19 on Nitto's
I realize that the rear tire is now larger diameter than stock and the front is smaller than stock. The rear fits perfectly with absolutely no rubbing and looks great, therefore I plan to stick with the 275/35/19 in the rear. However the front needs changed (too small, too much gap), as the rear is larger I would like to make the front slightly larger as well to keep the balance. That meaning 235/40/19. Question to the community will this rub at all on a 18x8 +40 offset? I am also debating 255/35/19, same question will it rub? The 255 will cause the front tire to be .1 inches smaller than stock while the rear is .6 inches larger, that is also a bit concerning for me. However I do not want to go to 275/30/19 like many have mentioned as that is .5 inches smaller than stock and I am trying to fill the wheel well better than stock (not planning on lowering).
Old 01-04-17, 05:31 PM
  #146
Jz39
Jz39's Avatar
I posted pics of the 235s previously. They look too tall and the front of the car literally feels higher when you are driving.
After finally seeing the 245/275 setup on 2011 rims in person, this will be the setup that I go with in the future. It looks proper and even with the slightly less tall sidewall, it looks very similar to the oem 225 sidewall height in front.
Dont make the mistake I made--go with the 245/275 setup.
Old 01-05-17, 06:24 AM
  #147
Lextasy4
Lextasy4's Avatar
Sorry, for some reason I thought that pick was 245. I personally am not a fan of 245/35/19 being that it is 0.3 in smaller than stock diameter, looking for smaller wheel well gap not larger. Ideal would be 255/35 but I only have an 8" wheel.
TruPlaya26
RC F (2015-present)
29
02-04-21 02:27 PM
ISFCOBRA
IS F (2008-2014)
21
09-25-18 12:38 PM
AndrewISF
IS F (2008-2014)
84
03-08-18 09:03 AM
qhrjsdl
03-06-17 01:13 PM
pep71
IS F (2008-2014)
04-20-16 09:30 AM
Quick Reply: Michelin PSS on OEM size
