Are these rotors due for replacement
Old 01-21-16, 02:06 PM
kiryu
kiryu's Avatar
Default Are these rotors due for replacement
Hi guys, does anyone know if my car is due for new rotors just by looking at these pictures? I have to change all pads, so if the rotors are due might as well change them as well
Thanks a bunch!
Old 01-21-16, 02:12 PM
ISFPOWER
ISFPOWER's Avatar
you need to measure it.
Old 01-21-16, 02:15 PM
kiryu
kiryu's Avatar
measure how deep the lip is?
Old 01-21-16, 02:50 PM
Vervish
Vervish's Avatar
Minimum thickness: Front - 28mm, Rear - 26mm
Measure like this:
Old 01-21-16, 03:13 PM
j3ff
j3ff's Avatar
^^exactly like that!
Op - those grooves are normal with our rotors; as is the lip. If you change just the pads you'll have to make sure you bed them properly so they'll seat with your grooved rotors. The minimum thickness is stamped on your rotor incase you need further reference.
Old 01-21-16, 04:02 PM
Compthis
Compthis's Avatar
Thanks a bunch!
Attachment 378306
Attachment 378307
Give them to me so I can put a few cracks in them then they're garbage
Old 01-21-16, 05:13 PM
I8ABMR
I8ABMR's Avatar
haha I save all my old rotors in case I need to trash a set on a track day. I know the dealer has replaced them with some meat on the old ones still
Old 01-21-16, 05:43 PM
kiryu
kiryu's Avatar
hey guys...thanks. I was gonna get my pads changed and the mechanic just said you need 4 new rotors just by touching the rotors....I am like ok..u didnt say that last time i saw you...
he did mentioned about those grooves and the lip showing etc.
Hmm....maybe I will ask them to measure it next time
Old 01-21-16, 08:03 PM
jspecvtec
jspecvtec's Avatar
I think it still looks good for a while at least..
Old 01-21-16, 08:34 PM
ISFCOBRA
ISFCOBRA's Avatar
i replaced my rotors and pads. The old rotors are still sitting on the garage floor waiting to be measured. I am pretty sure they are still good but will know once i measured them...
plus dont pay a mechanic to work your brakes.... These are the easiest brakes to swap out.
Old 01-21-16, 10:02 PM
kiryu
kiryu's Avatar
GGGRRRR i gotta learn how to be more handy. Probably need a bigger garage first to work on it
what tools do i need? floor jack, spanner....
Old 01-21-16, 11:14 PM
flowrider
flowrider's Avatar
Received 1,949 Likes on 1,372 Posts
^^^^Right Here:
https://www.clublexus.com/forums/is-...rake-pads.html
https://www.clublexus.com/forums/is-...09k-miles.html
Lou
Old 01-21-16, 11:36 PM
kiryu
kiryu's Avatar
Oh my...Lexus forum is the BEST
Old 01-23-16, 01:54 PM
lobuxracer
Tech Info Resource
Senior Moderator
lobuxracer's Avatar
Received 4,082 Likes on 2,474 Posts
Thanks a bunch!
Attachment 378306
Attachment 378307
Just looking at them? Not even close. Probably have 1.5mm to go at least.
Old 01-23-16, 02:02 PM
kiryu
kiryu's Avatar
Thanks Bud...seems like you just saved me some $$
Quick Reply: Are these rotors due for replacement
