again, measurements were spot on. got it all bolted up, and she sounds great! i'll probably get a sound clip tomorrow
Glad I could help anyone buying this exhaust! Also glad you verified my measurements. I havnt been able to install mine my pup tore his ACL so working on my car has stopped for a good while
My pit has had both his ACLs done. 2k a piece.... I feel your pain there brother.
have some exhaust rattle... havent had time to lift it again to see what it is... but i noticed on install it does somewhat hang low... wondering if its hitting both crossbars you have to remove just to take the stock exhaust off... hmmm
I had to trim a little off the muffler tips to fit them in. But other than that the car sounds great with no drone on the freeway
I bent the mid hangers up a bit and all is good in the hood
Mines actually sitting on the rear crossbar. I'm wondering if I take the crossbar out if it will do anything to the car it seamed like a really flimsy part anyways?
Mine was too... With the car on stands I used my jack and a block of wood on top to add height... Jacked the stock rear hangers on the car to slightly bend them up... Now it clears both crossmember bars under the exhaust... They are there for a reason, so I wanted to keep them there.
