X-Force Exhaust - Review
#451
Jondls33 that came out pretty good. Sounds good also.
Im still looking into getting those tips for my joez exhaust without deleting mufflers...
Btw you have a smal leak on the driver side pipe.
Nice job after all
Nice job after all
willstroo (04-27-17)
#453
I found this ones but theres a lot more on ebay it depends on which ones you like.... maybe this helps you
http://www.google.com/search?q=2x+du...RirAHUQgjYIsAM
With some recent negative experiences on eBay, I'm steering clear of them Amazon has them also:
https://www.amazon.com/Burnt-Exhaust.../dp/B00W571FNC
I'd much rather buy from Amazon.
But read the one review.
Lou
Lou
Thanks for the responses guys.
#455
Can anyone confirm yet if these will line up / work with the rear mufflers attached?
Getting sick of the exhaust smell.. And thats wil the primary cats still there! If i end up going the headers route then will need to pop some high flow cats into the exhaust, and will DEFINITELY need the tips through the bumper to minimise the smell.
#457
#459
Isn't there a reason we cant tape them up, cabin pressure equalisation? And you have to remove a section of the boot for one side from memory, will search the forum..
I still have primary cats and factory manifolds (widened), then X-Force with widened entry to match the modified primary cats.
#460
Just take the inner boot panels off and have a look you can tape them up just temp and see if it works. They are only there for cabin pressure when you shut the door. Hey going to Sonny's tomorrow for the tune and the cat widening will see how it goes cheers.Anything I should ask him before he tunes it.
#461
Ok ill have a look into the vents today, will see if it makes a difference. I thought i had to take out part of the boot to get to one side.. Will investigate..
Very exciting about the tune, your setup will be the same as mine, so interested to see the end power figure. Make sure you let me know!!
#462
My exhaust shipped today, can't wait to get it installed!
For anyone that has installed recently, are the Bosal gaskets still required for the manifold connection? Or has XForce started shipping better ones as of late?
#464
Did you experience any leaks with the gaskets that came with it?
