X-Force Exhaust - Review
#691
Both of those RR Racing options are axleback a for the Borla. They do sell a very similar exhaust like the Borla also, pricing is around the same as Joez. With headers you will have drone though just as you would with the regular Xforce. Bazooka would have the most as it would be the loudest.
#693
Maybe they just don't care
#694
It literally took my shop 7 hrs to install to get it right, very expensive install costs l didn't factor in.
#696
Lol...we have the same inspector number 008
Where are you located and who supplied the system to you?
Slowlane (08-04-20)
#699
Ok fellas, I got it installed a couple weekends ago and I did have to do a couple things to get it to fit.
1. Like Slowlane, I had to make a spacer for that rear crossbar to get it off the exhaust.
2. I had to bend one of the hanger posts to clear the chassis mount that holds the exhaust rubber insulators
3. i had to double up gaskets on one of the PPE header flanges, I DO NOT think this is an xforce exhaust issue as i had to do the same thing with the stock catback. (kind of sucks when you pay $3k for headers)
4. they have corrected the muffler hanger issue, they did not need any modification
5. i did not have clearance issues with the rear heat shield like Slowlane did
in before "thats not safe putting jack stands on wood"
but did i die tho?
but did i die tho?
The following 2 users liked this post by 93MSB:
footballpl (06-22-21),
funkifiedG (03-13-21)
#700
My car came with xforce exhaust when I purchased, I probably should take a peek under the skirt and see if I'm having any fitment issues or if they have been taken care of before.
#702
Just the Varex XForce cat back, I'm very happy with the quality of the sound plus I can make it quieter than stock at a press of a button. There's about 9 different valve adjustments as well via remote control.
#703
#704
but did i die tho?
but did i die tho?
How long did it take you to complete from start to finish including setting up ?
93MSB (08-25-20)
