X-Force Exhaust - Review
#721
I got my X-Force Varex installed a couple weekends ago and overall I'm extremely happy with it, can't beat it for the price and makes the car sound like how I think it should. I'm a big fan of being able to close the valves and have near-stock sound (slightly quieter) and lots of sound with the valves open. I'm surprised people complain about it not being loud enough when the valves are open. No it's not as loud as muffler deletes, get muffler deletes if that's what you want. It sounds like a nice straight through muffler, I love it. The sound reminds me of Coyote Mustangs.
I decided to hardwire my switch in one of the blank button spots on the left of the steering wheel, I didn't want to worry about battery or remote/communication issues like some have had. Plus the switch looks better than a remote hanging somewhere. Hardwiring a switch was as easy as hardwiring the remote box.
I removed the stock system and installed the Varex by myself of jack stands, it's completely do-able by yourself. The hardest and most time consuming part was removing the rusted and corroded stock exhaust manifold bolts. Besides that terrible process, it took me around 6 hours to install everything (including wiring the switch). I had the usual issues. Hitting the cross member, resolved by putting 1/2" spacers on the cross member bolts (1/4" was not long enough). The heat shield rubbed, I cut a small section off and bend it a little. The passenger muffler tip was 1/2" too long, I cut it (it's actually the pipe before the muffler that's too long, but cutting the muffler is the easy fix). I also had to trim the passenger stock exhaust outlet/tip because the muffler was rubbing.
All my pipes were built in March or May of this year, mufflers built in September 2020. I bought Fel-Pro gaskets for all joints except exhaust manifold where I used Remflex 8019.
I was able to sell my stock secondary cats for $400.
Cross member hitting.
Heat shield rubbing.
Hardwired switch.
Hardwired switch.
The following 2 users liked this post by footballpl:
AlOtaBblGm (07-29-21),
funkifiedG (07-26-21)
#722
i too am running the xforce midpipe with varex mufflers and i have been very happy with it. i do have ppe headers and the supercharger kit which goes very well together. i had some tips welded on as opposed to using the stock fake tips. it sounds amazing.
footballpl (07-27-21)
#723
Those tips look really nice, do you have a link for them?
#724
https://www.summitracing.com/parts/XFO-TYAW3563
these are the ones i used. my exhaust guy is pretty good he had to cut down the muffler outlet pipe then modify the exhaust pipe a bit to line up the muffler with the exit hole. then he welded he tips on from the inside of the tip so they wouldnt stick out too far. pretty happy with it.
ISFerr (07-29-21)
#725
The following 2 users liked this post by gixxerjp:
Positron (07-29-21),
WhyHateTho (10-15-22)
#728
Does anyone have audio clips of just the varex mufflers behind the secondary cats with headers (or primary cats removed)? I'm sure the car sounds awesome without any cats but I'm not going to go that far. I want to leave the secondary cats in.
#729
My production date was 03/2021. After going through many threads and facebook F groups I noticed that many xforce owner who reported no fitment issue has piping with a sandblasted/satin finish over the high polish finish.
I have not driven the car yet but it’s a decent exhaust for what you pay for. The downfall is that xforce/Summit had recently raise the price on the system ($1k non varex and $1600 varex). So the economical option may not be worth it anymore.
Some concerning things that I want to point out also:
1) The angle of the exhaust tips. The passenger side is quite close and tight to the framing of the OEM faux tip which could lead to some hotspot directed to the bumper.
2) Although the welds look fairly decent IMHO they appear to lack solid penetration. I know guys have reported no issues after a couple of years of ownership so that might be good news.
#730
I believe Xforce may have addressed the fitment issue. I installed my Varex setup this morning and other than the passenger side muffler tip being an inch too long everything else fits without interference. The cross bar issue seems to have been fixed as well as the hanger issue.
#731
#732
I can't say I had fitment issues, except for that I used weld on tips, so I had to cut and slide over the driver muffler to make it line up with the hole to weld on the tips. If I was using the factory tips I would have only cut down the muffler outlet a small amount. I used factory GSF exhaust gaskets for the header to midpipe gasket because it's a perfect fit. I have noticed on some of the ISF's if your rear bumper tabs are broken or your bumper sags, it will cause it to rub on almost any aftermarket mufflers using the factory tips.
#733
I've addressed the tips and varex motors with their r&d department. They seemed receptive & helpful. Even willing to replace a motor I fixed myself due to the pins backing out of the connector.
I believe most installs done where it rubs on the cross braces are due to not installing b the entire system loose and then incrementally tightening sections for adequate clearance & general fitment.
Aside from the passenger tip being too long, my system fits and clears perfectly.
It would have rubbed, had I not done the aforementioned.
Overall still very happy for the price.
As for the welds, they look great, just they have perfect fitment on their cuts and thus use a smaller filler rod when TIG welding. You don't need a massive bead for strength when your fitment is perfect. You can zero fill with TIG in some instances.
#734
Tech Info Resource
#735
