X-Force Exhaust - Review
#736
Anyone know if the cross brace bolts are long enough to add washers yo use then as spacers? My midpipe and brace caused clearance issues and the shop reinstalled it multiple times by having it loose and tightening/adjusting as best as possible. Never got it to fit right and have been driving without the center brace.
Picture below for reference on which bar. (Not my vehicle)
#737
#738
Nice. Care to share which spacers you got and does it clear to where you can still have the air panels installed?
#739
https://www.homedepot.com/p/Everbilt...0334/204604747
xdejablu3x (08-05-21)
#740
https://www.summitracing.com/parts/XFO-TYAW3563
these are the ones i used. my exhaust guy is pretty good he had to cut down the muffler outlet pipe then modify the exhaust pipe a bit to line up the muffler with the exit hole. then he welded he tips on from the inside of the tip so they wouldnt stick out too far. pretty happy with it.
#741
he actually welded the tips from the inside of the tip. He also had to cut and slide the piping a bit to make it line up. Then welded a band to keep it there
