anyone have a DIY on coolant change/flush
The following 3 users liked this post by JT2MA71:
Also the SLLC got new packaging recently...
- SKU:00272-SLLC2
Joe Z
Originally Posted by Lexus Drivers / IS F Scheduled Maintenance Guide
Drive Belt
Inspect for cracks, excessive wear and oiliness. Check the belt tension and adjust if necessary. Replace the belt if it is damaged.
Engine Air Filter
Check for damage, excessive wear and oiliness. Replace if necessary.
Engine Coolant
When inspecting, visually check the engine coolant level on the see through reservoir. Add coolant as necessary. When replacing, drain and flush the cooling system and refill with coolant. Always use Genuine Toyota Super Long-Life Coolant or similar high-quality non-silicate, non-amine, non-borate, non-nitrate ethylene-glycol coolant with long-life hybrid organic acid technology (i.e., a combination of low phosphates and organic acids). A qualified technician should perform these operations.
Note: Initial replacement is at 120 months/100,000 miles. Replace every 60 months/50,000 miles thereafter.
kzlflash (02-13-22)
kzlflash (02-13-22)
As @Rickna said, flush with distilled water, get a few gallons of those. And you’ll need 2 gallons of pre-mixed pink coolant, and will have a little bit of leftover.
Meh. Flush is a waste of time unless there's corrosion. I've never flushed mine and only added new coolant (like when I did the valley plate). Any distilled will only dilute the premixed coolant you put in there. Not exactly all bad depending on where you live. Running an 80/20 distilled to coolant mix is what I've done in my Supra for a very long time to minimize knock. Water is a far superior liquid for heat transfer, so more of it is just fine unless you live somewhere it gets genuinely cold. 80/20 distilled to Toyota red coolant freezes at 7 or 8F (I tested it) but was able to give me a whole octane point of detonation resistance.
The following 3 users liked this post by lobuxracer:
Blk04GS430
09-22-10 11:03 PM
