Camber questions when the F get lowered
Hello all! What do you guys suggest to buy to get the cambers on the rear ? because i'm gonna lower the F with Swift springs and I want to keep the rear stock lower control arms.
Thanks you guys!
Thanks you guys!
I don't think swift springs will lower it enough for you to have to worry about that....but definitely get an alignment done, they say wait about 2 weeks for springs to settle.
I need a camber adjuster due to i'm running 295/30 on the rear. It slightly rubs when I go over dips and bumps. So when the F get lowered I will rub into the fender more that why the negative camber needed.
