Need Help on O2 sensor DIY
Hello everyone!
I'm planning to replace my Bank 1 sensor 1 oxygen sensor, after having on going issue with the CEL, VSC light coming on and off from time to time.
Code: P2237, P2238
Current Mod: PPE headers with decoder, Borla full exhaust, cat removed.
I had done the downstream sensors replacement few years ago with help of many CL members. However, I had never done one for upstream Bank 1, sensor 1. I had done some research and find very limited DIY.
I would like to see if anyone can help me on:
1. confirm the location on the Bank 1 sensor 1 sensor (driver side of the headers?)
2. Exactly how to get access to it? (can I do it from the top of the engine base or do I have to left the car up and work on it from the bottom) Can I replaced it like this DIY on a IS250 (even with the PPE headers installed) : http://www.lexusownersclub.co.uk/for...1-replacement/
3. confirm I have the right replacement sensor: Denso 234-9048
Thank you very much for your help!
Code: P2237, P2238
Hello everyone!
Code: P2237, P2238
Code: P2237, P2238
2. With our headers on, you can get to everything from the bottom of the car. It is screwed in the header right before the outlet flange .
I would also check the wiring extension if it is heat damaged or melted, it can cause these codes .
3. Not sure the exact PN .
Received 1,064 Likes
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
You mean the A/F Sensor attached to the manifold / headers..
Doesn't matter what side but if you're going to do both the part numbers are the same.
Lexus Part No.: 89467-53020
SENSOR, AIR FUEL RATIO
Denso Part # 234-9048
Get some shielding for the new sensor wire harness![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Joe Z
Joe Z
