Those with a ECU tune , results please
Old 05-17-16, 11:34 AM
  #481
Ltaboso
Ltaboso's Avatar
Originally Posted by ShadowISF
7200 redline.
Are you also having issues past 6800 rpm?
I heard not everyone is having this problem,some 08s are lucky
Old 05-17-16, 11:47 AM
  #482
ISF4life
ISF4life's Avatar
mine has no problem
Old 05-17-16, 12:17 PM
  #483
jspecvtec
jspecvtec's Avatar
Originally Posted by Ltaboso
Are you also having issues past 6800 rpm? I heard not everyone is having this problem,some 08s are lucky
I'm pretty sure it's the same for all years. It's very hard to tell since you're going so fast but u can definitely feel it go neutral if u watch closely
Old 05-17-16, 09:08 PM
  #484
minator
minator's Avatar
Default CO Dyno
Hi guys, I went with MileHIFCar to dyno this last weekend and here are the results... He put down the same numbers as last time he went with Rohi123 (Rohi's dyno is shown below mine, he has - IHE no tune)
Yes, it is hard to compare dynos on different days, especially since the weather in CO is so variable, but looks like we have the same peak power, with me having 10 more lb-ft peak. It would be nice to overlay the graphs and see the difference under the torque curves...
Keep in mind we are dynoing in Denver, elevation 1 mile, also the correction is SAE.
Mine IHE, RR tune
Rohi123 - IHE
Old 05-17-16, 09:22 PM
  #485
Rohi123
Rohi123's Avatar
Mine IHE, RR tune
Rohi123 - IHE
Should have let me know I would have came again.
Old 05-17-16, 11:56 PM
  #486
ShadowISF
ShadowISF's Avatar
Mine has the problem but isn't that noticeable since I shift right after the beep.
Old 05-18-16, 08:56 AM
  #487
MileHIFcar
MileHIFcar's Avatar
Mine IHE, RR tune
Rohi123 - IHE
The 10 Ft Lbs of torque that you put down more than Rohi123 (in my estimation) has to do with the tune I'm guessing?? My guess would be that a few more runs on the dyno might have shown better gains
But as always I think those are pretty good numbers at the elevation here, and after talking to one of the dyno operators, he said that it was not corrected for sea level numbers?? So if that's true that's what our/your numbers are at mile high in elevation which is pretty good I think!?
Old 05-18-16, 11:17 AM
  #488
Ltaboso
Ltaboso's Avatar
Minator did you do the learning process correctly?
Old 05-18-16, 12:55 PM
  #489
ISF4life
ISF4life's Avatar
yeah mine is like that , the more we ran the more hp i gain . Because i didnt get much chance to drive my car much prior to re dyno. so before tuned about 400whp after should get like 415 to 420 if weather is cooler a bit even more.
Old 05-18-16, 01:23 PM
  #490
poorbong
poorbong's Avatar
Hahahaha you wish!!! jk
Old 05-18-16, 01:28 PM
  #491
jspecvtec
jspecvtec's Avatar
Hahah burned! All I know is I'll always have more power than Kody even without intake LOL
Old 05-18-16, 02:15 PM
  #492
ISF4life
ISF4life's Avatar
Originally Posted by jspecvtec
hahah burned! All i know is i'll always have more power than kody even without intake lol
well ppe header has about 5 to 8 whp more than sikky
Old 05-18-16, 07:22 PM
  #493
jspecvtec
jspecvtec's Avatar
We should have the same hp if u say intake makes 5whp then lol
Old 05-25-16, 03:24 PM
  #494
rselby
rselby's Avatar
so now that there is a few tunes on the road, has anyone noticed any decrease in fuel mileage ( when driving normal ) and has anyone requested a higher idle speed with AC off...I would like mine to be a little bit higher and seems too low , but maybe I'm the only one, don't hear much about it
Old 04-25-18, 05:32 PM
  #495
redspencer
OG Member
redspencer's Avatar
I haven't seen this mentioned on this thread but for those of you datalogging your tunes and would like to see what your Knock Correction Learning Value (KCLV) and Knock Feedback Value are without the use of Techstream, you can do so by downloading the phone app "OBD Fusion" as well as the Toyota Enhanced Diagnostic PIDs.
I recently picked up this tidbit from Rafi and Simon @ RRRacing and was able to easily read my KCLV (24 @ WOT) and to see if the car is pulling back any timing (-3 degrees at idle and WOT).
The following 2 users liked this post by redspencer:
ImportISF (04-30-18), tas02 (05-12-18)
Quick Reply: Those with a ECU tune , results please
