Right tire size. ISF
I have a question I currently have 235/40/19 in the front on my isf and they are rubbing a lot on turns, and I wanted to go down to 235/35/19 and I was wondering those the 35 have less of a load capacity? Then the 40 or what is the main difference between the to sizes? Thanks
Depends on what wheels your running? You on stock wheels? Or aftermarket?
Most of the guys here that are running upsized tires are running 245/35/19 & 275/30/19 me included and I don't rub with aftermarket wheels with a +40 offset up front width 8.5" and a +45 offset in the rear width 9.5"
Most of the time if you have issues rubbing it's because of a aggressive offset with aftermarket wheels
225 x .40 = 90
90/25.4 = 3.543
3.543" x 2 + 19 = 26.086" tall
235 x .40 = 94
94/25.4 = 3.7"
3.7" x 2 + 19 = 26.4" tall
235 x .35 = 82.25
82.25/25.4 = 3.238"
3.238" x 2 + 19 = 25.476" tall
Lou
To the op... are you on the stock front wheel? Stock suspension height?
Seems a change solely from a 225/40 to a 235/40 shouldn't have you "rubbing a lot in turns" unless there are additional changes made to your F.
Thanks Lou for the chart addressing the poster's issues.
Dennis
Dennis
bighitbike
06-11-07 10:23 PM
