Tire Grinding Due to Camber?
It's like a tire grinding or shuffling at low parking lot speed, hard right or left turn, more evident when slowly braking during the turn. Dealership claims the negative camber contributes to this phenomenon and that nothing can be done about it.
I realize we have about a 1.5-degree negative camber in 2011-and on IS-F (I have no mods and still running with stock Potenza RE-050s), perhaps this contributes to the feel of the tires at parking speeds. Its a fairly minor nuisance but anyone else experience something like this?
Former Sponsor
That shouldn't have anything to do with camber. I street drive my track car with more than -3 degrees of camber and have never experienced what you're describing. To me it sounds like toe is more of your issue. Have you had the car aligned recently? Do you know what your alignment is (or should be)?
Matt M.
Matt M.
Tech Info Resource
It's a combination of a lot of caster and likely toe not exactly happy. The F has a pretty tight turning radius too. I notice this most below 45F OAT on summer tires. I had hoped replacing the rear LCA bushing would eliminate this, but it only minimized it. I still get some suspension noises from the tires at high turn angles and parking lot speeds.
That's the long winded way of saying, "it's kind of normal."
Is the tire worn evenly? Does it have any unevenness that could cause chatter? 1.5% of camber is not going to cause issues if the toe is correct. Did you check the caliper or pad?
I have the same issue. at far turn radius and slow speed / parking lot I thought I was rubbing the inner plastics - but seems it is the tire.
If you ever look at the geometry of the tire from outside when it is turned fully you will be surprised at the angles
Wow thanks for all the inputs and sorry I've been offline for a few hours. To answer some of you, I've just had this car about 2 months, and it has just 31k miles so no I've not had an alignment done. Although it seems to track very straight at all speeds. Both The front tires have extra wear on the inner shoulder of the tire and for a while I also worried they were rubbing against something but not sure about that yet. The Lexus mechanic said this sensation is not unusual but it's more pronounced on some is-Fs more than others...
Other than the inner wear on the fronts, the tires all seem to be wearing evenly and there's plenty left on the brake pads.
