Wheel fitment
Looking to the forum for help on deciding on tire size and if the FIGS racing arms will be needed, and/or any additional equipment.
I will be lowering on KW v3 and I've narrowed my wheel selection to the following specs:
19x9.5 +22
19x10.5 +22
I'm also aware that I will need to roll/pull my fenders to make this setup a reality.
Any help is appreciated for whom have gone for aggressive setups.
19x9.5 +22
19x10.5 +22
https://www.clublexus.com/forums/is-...f-pics-43.html
Depends on how low you take it, the front will be ok with some minor work to the fender liner.
The rear will need fender rolling/pull and the figs kit will help also camber kit.
Tire sizing will play a part in fitment also
Fivepoint0 mentioned pretty much everything. The offsets are a bit on the aggressive side, so there will be a need for camber. If you're looking for performance tires, to keep from rubbing, the FIGS kit will help with some camber.
19x9.5+22 !?! Thats a little aggressive . Damn ! Why not get a set that fits a little easier ?? Or are you going for a stance/hellaflush look ?? More power to you bro. Good luck
Thanks for the input guys. It looks like there's quite a bit of work to be done to fit a +22. Not too big on stretching tires. Looks like I'll step down a bit and go with 19x9.5 +40 all around. Does this tire sizing look good or do you recommend something else?
235/35/19 front
265/30/19 Rear
235/35/19 front
265/30/19 Rear
Tech Info Resource
235/35/19 front
265/30/19 Rear
235/35/19 front
265/30/19 Rear
235/35/19 front
265/30/19 Rear
235/35/19 front
265/30/19 Rear
Best of luck!
If you're looking for aesthetics, either one of those specs will be right on the money. I'm pretty similar and have the same sized tires, lowered on Eibach springs and soon to be bags. Looks amazing, and the performance isn't drastically cut like some users suggest (unless you're a track fiend). You won't see a decrease in daily driving, and I drive pretty spirited.
The only fault I have in my setup is these Hankooks that are made of rubberized dog ****. I'd recommend some good tires and you'll be a-ok, minimal rubbing with 2.5* of camber in the rear and pretty much none in the front.
Then again, take into factor that my name is lolfunction and I'm not known for making functional builds. I think the very minimal performance sacrifice for a head turning setup / ride is well worth it. I still have plenty of fun dailying this setup, but I've never had any interested in track days.
My setup, for reference
![Name: CE9E7F6C-02E6-4432-8B81-2632F2B5D805_zpsscjg9h8c.jpg
Size: 176.8 KB](https://www.clublexus.com/forums/attachments/is-f-2008-2014/444038d1501528246-wheel-fitment-ce9e7f6c-02e6-4432-8b81-2632f2b5d805_zpsscjg9h8c.jpg)
![Name: 24149363066_23f689a89e_o_zpstfntausv.png
Size: 1.26 MB](https://www.clublexus.com/forums/attachments/is-f-2008-2014/444039d1501528246-wheel-fitment-24149363066_23f689a89e_o_zpstfntausv.png)
![](http://i1343.photobucket.com/albums/o795/chasewrx/CE9E7F6C-02E6-4432-8B81-2632F2B5D805_zpsscjg9h8c.jpg)
![](http://i1343.photobucket.com/albums/o795/chasewrx/24149363066_23f689a89e_o_zpstfntausv.png)
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
