Will a GS-F Steering Wheel fit an IS-F?
Old 03-04-16, 10:00 AM
MGmbH
MGmbH's Avatar
Default Will a GS-F Steering Wheel fit an IS-F?
Like the title says - will a GS-F Steering Wheel fit an IS-F?
Drove one this weekend and loved the look and wider feel. I know there are a bevy of steering wheel solutions for the IS-F but it could be interesting to carry this over if possible.
Old 03-04-16, 10:20 AM
mjeds
mjeds's Avatar
same steering wheel that is on the RCF.
while is suspect it will "fit" I also suspect you will have issue with the steering controls.
your controls from the ISF will not move over as the under frame design is different, so the mounting/bolt locations are different:
ISF wheel frame:
http://lems.ocnk.net/data/lems/produ...015_c304bb.JPG
GSF/RCF frame:
https://cimg0.ibsrv.net/gimg/www.clu...8fc070030b.jpg
now you might be able to also swap in the GSF/RCF controls and air bag, the question would then be whether or not they work the same to control your vehicle.
Old 03-04-16, 10:55 AM
MGmbH
MGmbH's Avatar
ISF wheel frame:
GSF/RCF frame:
Got it. Thank you for taking the time to dig that up.
It feels like it would be more trouble than it's worth. After driving the GS-F, i cant help but feel like the IS-F wheel is so thin.
My car is L Certified - any one have experience swapping the steering wheel and maintaining the warranty? I guess I could have the current steering wheel re-wrapped...
Old 03-04-16, 11:43 AM
Meraki Autoworks
Your #1 Lexus Vendor
CL Vendor - Starter
Meraki Autoworks's Avatar
I just bought an entire whole new wheel. x10 better than OEM. Check out my build there, there are some pictures in there. The link is in my signature, '10 ISF.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 03-04-16, 11:53 AM
MGmbH
MGmbH's Avatar
-Josh
Great build thread, Josh. Big fan of this steering wheel -
Did you mention in the thread where you picked that up? Sorry if I missed that. Would be interested in an all leather version.
Thanks
Old 03-04-16, 11:55 AM
Meraki Autoworks
CL Vendor - Starter
Thanks
It's from some guy in Australia.. Don't remember who..
-Josh
__________________
Orange County, CA
Old 03-04-16, 11:57 AM
RSXiMUS
RSXiMUS's Avatar
If you like thicker wheels, try out a 2011+ ISF wheel. Should be direct swap in for your 2010, It feels substantially thicker than the older ones.
As per Flowrider's thread, I used his measurements for his stock 08-10 ISF wheel vs. my 2011+ wheel for comparison. I used a digital caliper.
08-10 wheel vs. 2011+ wheel
Top OD - 1.15" vs. 1.4"
Grip OD - 1.11" vs. 1.45"
Above Grip OD - 1.35" vs. 1.55"
Just Above the Above Grip OD - 1.15" vs. 1.42"
Bottom OD - 1.16" vs. 1.35"
Old 03-04-16, 12:26 PM
flowrider
flowrider's Avatar
Received 1,949 Likes on 1,372 Posts
Forum Sponsor DCTMS built my wheel for me. I luv it.
https://www.clublexus.com/forums/is-...s-morning.html
Lou
Attached Thumbnails Will a GS-F Steering Wheel fit an IS-F?-wheel-eight1.jpg
Old 03-04-16, 12:39 PM
RSXiMUS
RSXiMUS's Avatar
If I were to switch steering wheels, I'd definitely go with Flowrider's "thick" wheel, looks awesome.
Old 03-04-16, 12:40 PM
mjeds
mjeds's Avatar
your warranty on the wheel would be void, and on anything that they claim the wheel can affect..
for example, if the steering controls all of a sudden stop working.
or the airbag does not go off. A case could be made against the steering wheel.
but if your alternator or A/C were to fail, that would not be a direct cause of changing the steering wheel.
make sense
Old 03-04-16, 01:23 PM
lolfunxion
lolfunxion's Avatar
I wouldn't trust the airbag to go off in an accident from a different model car. Echoing what these guys said, get an aftermarket one made for the IS-F.
Old 03-04-16, 01:37 PM
PDP180180
PDP180180's Avatar
Agree with op that the stock wheel is too thin.
Here's mine after a retrim. It was an aftermarket wheel from the guys in Cali that sell through eBay. I've had them put another full skin of leather on it, then another layer of leather top and bottom, and alcantara on both sides. They also added a red leather racing band at 12 o'clock, and finished it with the OEM style light blue stitching.
Hope you like it.
The hand shots give you a gauge of the thickness.
Love how it turned out.
Old 03-04-16, 07:00 PM
k20trick
k20trick's Avatar
Lou
Definitely digging that wheel if they did that center strip on the middle top that would sweeten up the deal, but looks like the carbon matches our factory one perfectly. Best one I've seen so far!
Old 03-04-16, 07:02 PM
flowrider
flowrider's Avatar
^^^^Thank You. I thought about the strip when I ordered it, but decided against it at the time.
Lou
Old 03-05-16, 04:31 PM
scorpionge
scorpionge's Avatar
good freaking lord thats an amazing steering wheel! @MGmbh
Quick Reply: Will a GS-F Steering Wheel fit an IS-F?
