MAF and Throttle Body Cleaner
Old 03-19-16, 04:30 PM
F_Throttle
F_Throttle's Avatar
Default MAF and Throttle Body Cleaner
I had the intake off today, and noticed that there is gunk in my TB:
Is this normal? The car has 65K miles on the clock. Should I run some TB cleaner through it, and at the same time MAF cleaner through the sensor?
Also, I looked at my stock airbox and was wondering if this needs replacing:
What is this?
Old 03-19-16, 08:41 PM
IS_250
IS_250's Avatar
that carbon filter is riveted to the inside of the air box. It is not replaceable.
What is this?
Old 03-20-16, 01:37 AM
Defratos
Defratos's Avatar
Firstly that TB gunk is normal, especially if you've never cleaned it through the 65k miles.
I usually clean my TB whenever I'm cleaning out my filter.
I use some WD-40 on a cloth and wipe off the gunk.
Be careful on the MAF as you need to use the right cleaning products so you don't mess up the sensor.
I believe only Isopropyl Alcohol is used for MAF cleaning, I don't know of any other product that can be used to clean the MAF
Old 03-20-16, 02:07 AM
hamooduae
hamooduae's Avatar
http://i72.photobucket.com/albums/i1...1/IMG_1627.jpg
i guess iv done many researches and see alot use this CRC MAF cleaner
Old 03-20-16, 06:34 AM
newgsman
newgsman's Avatar
Haven't used CRC MAF on my 2012 ISF yet but I have been using it for years on my '98 GS400. Works well. I clean both MAF and throttle body with it.
Old 03-20-16, 12:20 PM
Defratos
Defratos's Avatar
Looks like it'll get the job done since it's specific to MAF sensors.
Have you found anything like this in our region Hamood?
Old 03-21-16, 09:54 AM
F_Throttle
F_Throttle's Avatar
I was going to use CRC TB cleaner for the TB, and CRC MAF for the sensor.. I've been using it for years before, but I never worked on the F.
I don't suppose anyone here also uses the 'Seafoam'? Or is this a dated maintenance task?
Old 03-21-16, 10:51 AM
Weapon F
Weapon F's Avatar
They recommend that you clean your MAF every time you change your air filter. I clean my MAF once year, make sure you use quality MAF cleaner they are designed not to damage senor on MAF. I use CRC MAF cleaner, if you haven't cleaned your MAF once you cleaned it you will notice sharper throttle response, you'll feel slight bump in power and better fuel economy
Old 03-21-16, 11:01 AM
ISF4life
ISF4life's Avatar
Exactly , clean the air filter box and the inside of your intake tube too while u at it
Old 03-21-16, 11:31 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,990 Likes on 2,414 Posts
Attachment 382111
Who is they? The oiled filter manufacturers? Lexus does not recommend cleaning the MAF element unless it is part of troubleshooting a MAF problem. I have never cleaned mine and have no expectation of ever cleaning it because I run the OEM paper filter.
If there is anything on your MAF or in your intake tube, your filter is not filtering and you might as well just run without one.
Old 03-23-16, 11:56 PM
hamooduae
hamooduae's Avatar
Yeah , got mine from ACE HARDWARE , thats the only place we have it available
Old 03-24-16, 01:08 AM
jspecvtec
jspecvtec's Avatar
U need an air oil separator
Old 03-24-16, 10:47 AM
Rebel22
Rebel22's Avatar
I've seen some posts on these and might be getting one.
jonas's RX
02-24-18 04:02 PM
Jabberwock
02-20-15 02:39 PM
MValentine
02-04-13 07:41 PM
VJZ
Performance & Maintenance
13
04-03-08 10:48 AM
Drewbeeee
07-23-07 11:03 PM
Quick Reply: MAF and Throttle Body Cleaner
