fellow ISF owner suspension opinions
Old 03-25-16, 05:58 PM
Bigjon3475
Bigjon3475's Avatar
Originally Posted by Dnfwm
More than anything I would love to jump in on that Penske deal and in theory I could afford it, I just have a hard time justifying it. That 3250 U.S. will end up costing me 5,000 or more and I just don't think I can come to terms with that.
It's $2950 with the group buy code and $3200 with USRS added and correct code for the combo.
It should be $4115 CAN...
Just saying... Not trying to convince you or anything. That's still a lot of moola!
Old 03-25-16, 08:49 PM
Supraman16
Supraman16's Avatar
My vote for HKS Hipermax GT4 coilovers. 16K front/10K rear spring. More comfortable than stock and handles like it's on rails!
Old 03-25-16, 10:41 PM
shyguyF
shyguyF's Avatar
You got a GT or SP version ? which one is stiffer ? I like something that is stiff as 08 stock suspension or stiffer but not harsh. Can you upgrade to 12K for the rear ? Thanks buddy ?
Old 03-26-16, 10:28 AM
lorenr
lorenr's Avatar
Originally Posted by tas02
Old guy rant here, just gotta ask...
Why is it that so many consider "good looking" to be stretched tires fitted on heavy, larger diameter rims with offsets 20-30 mm lower than stock, with way too much camber needed to make them fit on their overly lowered car?
To these eyes it makes the car appear to be modded on the cheap, like it's owner couldn't afford to install parts that fit and work together to enhance both the looks and performance of the vehicle.
I know that many have spent lots of cash to achieve an "agressive stance". But just ask yourself how agressive is it to have to drive like your grandmother just to roll on our crappy, poorly maintained roads?
Looking forward to lively responses.
Dennis
Every time I see one of these cars with the goofed up wheels, I secretly hope the person saved the stock parts to make the car right again. The crazy camber just ruins the tires and probably the wheel bearings.
Old 03-26-16, 11:43 AM
Dnfwm
Dnfwm's Avatar
Wow, talk about blowing the budget right out of the water! I just jumped in on the rr racing Penske deal with the rr racing usrs!
I thought very long and hard about it and too many times in my life I have cheaped out on stuff and wish I would have bought the better product! Not this time! What sold it for me was watching the rr racing ISF hang with the track prepped f430 and track prepped Elise. very impressive suspension and I am looking forward to my new purchase!
The following 2 users liked this post by Dnfwm:
21ce (03-19-23), Ayonapkinz (08-17-20)
Old 03-26-16, 12:20 PM
bnizzle87
bnizzle87's Avatar
Congrats, Dnfwm! Looking forward to seeing your runs on the track. Anything else planned to make it completely track ready?
Old 03-26-16, 03:00 PM
Dnfwm
Dnfwm's Avatar
Hey thanks bnizzle! I still want a set of headers. When it comes to the headers they both pretty much make the same power so I would rather have Whichever ones are cheaper. This dollar conversion really sucks! If any one has some for sale pm me a price. Or if a sikky dealer can pm me their best price, please feel free.
As for track mods, I have a 245/275 setup on right now that I will probably burn off in May at the first track event. They are about half worn right now, so I might as well burn them right off. At the first event, I'm going to see how the stop tech pads do with higher temp fluid. I will probably end up getting dedicated track pads. I am also going to have to way the pros and cons against Pilot super sports and R compounds and make a decision.
Rafi was saying that these penske's are so good that I won't need to buy sway bars, so I'm happy about that. Other than that, I will just play it out as the year progresses and see where I end up. I would love to have an os giken or a torsen, but that is for sure not happening this year.
Old 03-26-16, 07:35 PM
5280ISF
5280ISF's Avatar
Congrats! What springs did you decide to go with? 16K / 14K?
Old 03-26-16, 08:51 PM
Supraman16
Supraman16's Avatar
I think there is only one version of HKS Coilovers for the IS-F: the GT4's. I think the 16K/10K setup is perfect for the ISF. Very neutral handling and also very comfortable for daily driving. It's still stiff, but no where near overdampened as the stock 2008 suspension. You can upgrade to 12K rears if you want, but I suspect you'll have a degree of oversteer with the stiffer rear springs.
Old 03-26-16, 09:38 PM
Dnfwm
Dnfwm's Avatar
Thanks man! I hope you get it figured out and jump in too!
I decided on the high spring rates (18k I think). I figured if it's too severe I can buy the other springs.
Old 03-26-16, 10:24 PM
blackisF08
blackisF08's Avatar
how long have you had your hks set up for?
Old 03-29-16, 10:31 PM
FIGS
The Maker
FIGS's Avatar
On the 2008 you should have really considered our rear toe link and LCA. Reducing rear bumpsteer is a huge improvement to overall handling stability at speed.
Regarding spring stiffness just remember that stiffening implies reduction in travel and travel is really what nets grip. We add spring rate when we are adding additional grip via tires, brakes or trying to target a new corner weight. Its a system that all has to work together and the suspension travel has an impact on steering particularly in the rear with the toe link sweep. Suspension geometry changes will be superior in the overall driver confidence and that is what matters most. As you upgrade one thing you surely find the next at the track. Just have fun and be safe.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 03-30-16, 10:19 AM
Supraman16
Supraman16's Avatar
I've had them now for over 1 year. Love them so much more than the BC Racing coils I had before.
Defratos
IS F (2008-2014)
19
04-28-20 08:49 AM
blackisF08
07-22-18 04:21 PM
blackisF08
IS F (2008-2014)
10-04-16 12:55 PM
RRRacing
CL Vendor Products for IS-F
63
11-03-15 05:03 AM
irhasIS350
Suspension and Brakes
03-13-12 07:36 PM
Quick Reply: fellow ISF owner suspension opinions
