VP Racing OCTANIUM
VP Racing OCTANIUM
Well today, I decided to go to my local autozone to get some fuel addictives. On the shelf as I was looking, I came upon a product I have never seen before.
VP MADDITIVE OCTANIUM octane concentrate
I know magic does not happen in a bottle but I was curious so I got me a bottle and their fuel cleaner as well. As soon as I left the store, I put it all in. I had a little over half tank gas so I figure it wouldn't hurt. I also put in their fuel cleaner product as well. I drove about 5 mins to get the fuel to mix. I decided to get some breakfast so I stop by a Starbucks. As soon as I get in my car and start it................ (Hoping for some kind of feeling that it works). It feels normal as always so I proceeded to drive to a more designated spot where I do my "speed" test run. It could be just the placebo effect but as soon as I gun it, it pulls....it pulls HARD. It really feels like the last time I pumped a full tank of 100 octane gas but it could also be the fuel cleaner. I did a quick research and I still can't find much info on this but from my butt dyno, it seems to work but I want to hear what you guys have to say or feel? Can this bottle really give up to 8 FULL octane numbers?
I have been using NOS Racing Formula octane booster and I wouldnt say the car is faster as much as it just idles so smooth feels nicer around town
I used this before since I used to get it from work for cheap, might be a placebo effect but I feel like it worked. BMWs always used to come into the shop with an empty tank before a dyno run and fill up on these. It made significant power but I understand those are tuned engines.
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
A cousin of mine has an RS6 (I know it's not comparable) but he had someone come tune his car on the road and he recommends putting a bottle of octane booster in your normal fuel to give you better output.
To me I see it this way, cleaner fuel = better effeciency = better output.
Placebo yes maybe unless you can compare two identical cars with idcentical drivers and datalog everything.
I put in injector cleaner every 2,500km because out fuel is crap here, I personally believe it helps.
On top of that I fill up my car from only 1 fuel station in the city as this tuner has proven it has cleaner fuel than the others, this I feel does make a big difference as I notice the car does pull much harder and keeps pulling.
Maybe its placebo effect but I do feel the car is running healthier.
I used to put lucas injector cleaner in my car alot. I was told it was a waste but I always like to go the extra step in keeping a good running car.
I know that those octane boosters are not good if you use them all the time as it can burn up your rings.
Also I have a ???? Can you guys not get 93 octane premium??? Im in NC and have always used this. Not saying +2 octane is much more of a difference but just asking.
This is not the case at all. 100+ octane/racegas prevents knock/compression detonation. Knock can happen in NA motors when they have high compression ratios for more power and a higher octane gas is required. There are plenty of NA race cars running 100+ octane fuel. Race gas can also help in situations where heat soak is causing high cylinder temps by preventing knock.
This is why I use the octane booster for all track days. Race gas is not that easy to find.
Tech Info Resource
No booster in a bottle that small will give you 8 points. Maybe 0.8, but definitely not 8 points. VP would put their own racing fuel business in jeopardy if it really worked.
Yet another thread about hoping something will work when it has been proven too many times it does not. Just look up the MSDS on it and you'll see the majority of it is kerosene which has a surprisingly low blending octane (that's the C2 to C20 aromatic hydrocarbons on page 3). They have something else in there, MMT, which I have found likes to leave deposits on your plugs in the long run. Oh, yeah, maybe I forgot - I've tried all this stuff...none of it works, and VP says not for use in cars with catalytic converters - it will clog them prematurely.
You'd be way ahead just to pay for 100 octane unleaded. In a 16 gallon tank, you need 4 gallons of 100 octane with 12 gallons of 91 to get a 93 octane mix. It worked marvelously in my Supra in California and got me back to 18 mpg around town from 12 mpg around town with the evil **** they call 91 octane in Cali. It also ended up being cheaper because the fuel economy was so much better - and this is on a bone stock engine from Toyota, not some APU monster.
And BTW, if you have a problem with heat soak, you need to remove the coolant and replace it with pure distilled water and a higher pressure cap or get a bigger radiator (not thicker, but more square inches). Nothing moves heat as well as water, and if you're on the track and your cooling system takes a dump on you, everyone else will be damned happy you're running straight water. You can't race a motorcycle with coolant in it because it makes a huge slippery mess for everyone else.
No booster in a bottle that small will give you 8 points. Maybe 0.8, but definitely not 8 points. VP would put their own racing fuel business in jeopardy if it really worked. Yet another thread about hoping something will work when it has been proven too many times it does not. Just look up the MSDS on it and you'll see the majority of it is kerosene which has a surprisingly low blending octane. They have something else in there, usually MMT, which I have found likes to leave deposits on your plugs in the long run. Oh, yeah, maybe I forgot - I've tried all this stuff...none of it works. You'd be way ahead just to pay for 100 octane unleaded. In a 16 gallon tank, you need 4 gallons of 100 octane with 12 gallons of 91 to get a 93 octane mix. It worked marvelously in my Supra in California and got me back to 18 mpg around town from 12 mpg around town with the evil **** they call 91 octane in Cali. And BTW, if you have a problem with heat soak, you need to remove the coolant and replace it with pure distilled water and a higher pressure cap or get a bigger radiator (not thicker, but more square inches). Nothing moves heat as well as water, and if you're on the track and your cooling system takes a dump on you, everyone else will be damned happy you're running straight water. You can't race a motorcycle with coolant in it because it makes a huge slippery mess for everyone else that is very difficult to clean.
