Crack in Exhaust Manifold...
Old 10-23-18, 07:48 PM
  #256
McPierson
McPierson's Avatar
Epic post man. Thanks. I’m dreading it even more now. It’ll be a good chance to get to know the car though.
Old 10-24-18, 03:57 AM
  #257
Joker4096
Joker4096's Avatar
Sikky has a pretty good installation video on YouTube on how to install aftermarket headers if you need a visual.
Old 10-24-18, 05:05 AM
  #258
McPierson
McPierson's Avatar
Yeah thanks. KG does also. I was hoping I wouldn’t need to drop the subframe. It’s good to know I can unplug the O2 though.
Old 10-24-18, 07:48 AM
  #259
steeven001
steeven001's Avatar
The extra hour you spend to drop the subframe is worth it instead of getting frustrated trying to work around it and you'll be able to get your torque wrench in there to tighten the manifold to spec.
Old 10-24-18, 01:30 PM
  #260
McPierson
McPierson's Avatar
Excellent response. I should be adding the FIGS LCA bushings anyway. So I'll do both at the same time and get an alignment.
Old 11-01-18, 06:55 PM
  #261
BlckGhst
BlckGhst's Avatar
Got this done today on a lift. Not a bad job. Disconnected steering shaft from the rack, mounts, and sway bar, and subframe drops a few inches. Enough clearance to remove the shields and manifold. Engine mount did not have to come off. With the right combination of sockets and extensions, all the manifold nuts are easily accessible. I think it took longer waiting to get the part back from the welder
Old 11-01-18, 08:05 PM
  #262
McPierson
McPierson's Avatar
nice looking weld. So is the design of the rear flange that the flange is welded to the back tube but loose over the front?
Old 11-01-18, 08:15 PM
  #263
BlckGhst
BlckGhst's Avatar
Thats correct
Old 05-26-19, 12:38 PM
  #264
kzlflash
kzlflash's Avatar
So I'm planning on removing my PPE headers and going back to stock headers.
Before I do so I'm planning on taking my stock headers to a shop to have the welds reinforced.
Anything I should know of or beware of prior to doing so? Any best practices or tips I should give the shop a heads up on?
Old 05-26-19, 02:01 PM
  #265
drifto
drifto's Avatar
Can I buy your PPE headers off you?
Old 05-26-19, 10:23 PM
  #266
av8or
av8or's Avatar
Count me in as another victim. I was contemplating on getting the PPE but decided to just get the brand new oem that was for sale here on the boards. I have the hayward and scott exhaust and it is loud enough as it is. Pairing it with PPE would make it insanely louder and would attract unwanted attention from the cops here in CA. Stupid CA noise law.
Old 05-28-19, 03:18 PM
  #267
Wh0pp3r
Wh0pp3r's Avatar
Thinking ill keep my headers once the swap with PPE is done. never know.
Old 11-11-19, 10:56 PM
  #268
cvt
cvt's Avatar
So does anyone know how to look for these with a borescope? I’ve been trying to slip a borescope through the heat shield from up top and it’s very difficult
Old 11-14-19, 12:01 PM
  #269
lawrence1
lawrence1's Avatar
You can probably go through the bottom ... remove heatshields and it should be doable. The noise is what gives it away though. If you get exhaust leak ticking noises on cold starts then you know the pass side is going to be cracked. The driver side cracking is less common.
Old 11-14-19, 01:41 PM
  #270
cvt
cvt's Avatar
dang it. I was afraid if that.
Quick Reply: Crack in Exhaust Manifold...
