Issue with Driver door Unlocking w/fob and Handle
Hey guys, wanted to know if any of you have experienced this issue. My F started to do this a couple of months ago. It will not unlock the driver side door with either from the handle (while key in your pockets) or with the key fob (when pressing the button). If i go to the passenger side and place my hand on the handle it will unlock the doors except the driver.
Is there any remedy to this? Does it have to do with the Actuator?
Have you tried using the key, unclip the cap and manually open the door with the key if it works your door solenoid is on the blink, take the inner door panel off and spray the solenoid and linkages with wd40 and go from there, it could be stiff or stuffed let the forum know what you find.
Jayss01
RX - 1st Gen (1999-2003)
06-10-17 11:49 PM
ES350Bob
ES - 5th Gen (2007-2012)
18
12-19-06 10:02 PM
