My car won't start
Old 04-11-16, 04:38 PM
NSXGuy
NSXGuy's Avatar
Default My car won't start
Have electrical power but only getting a clicking sound. Bad starter?
Old 04-11-16, 04:43 PM
Compthis
Compthis's Avatar
Is the battery good? Sounds like a bad battery.
Old 04-11-16, 04:50 PM
ISF4life
ISF4life's Avatar
Dead battery , time to replace redtop battery
Old 04-11-16, 05:08 PM
NSXGuy
NSXGuy's Avatar
Battery is fine I think? Even tried tried to jump it but still the same.
Old 04-11-16, 05:24 PM
Joker4096
Joker4096's Avatar
Could be starter. Any way you can get a hammer and hit it? Maybe with an extension or something.
Old 04-11-16, 05:27 PM
NSXGuy
NSXGuy's Avatar
Was thinking about doing that. Where is the starter on this car?
Old 04-11-16, 06:48 PM
specie
specie's Avatar
Use a non-metal item or the non-metal end of the hammer. Can accidentally cross the + and - with a metal object.
Old 04-11-16, 07:07 PM
5280ISF
5280ISF's Avatar
This thread should help...
https://www.clublexus.com/forums/is-...-to-start.html
Old 04-11-16, 07:27 PM
MileHIFcar
MileHIFcar's Avatar
From the sound of the install you'd might save some time on labor if you wanted to install headers at the same time unfortunatley
Old 04-11-16, 07:50 PM
NSXGuy
NSXGuy's Avatar
I get a series of clicks before it goes silent. Fortunately it's still under the power train warranty so I should be covered. Having it towed to the dealership tomorrow if hitting it does not work.
Old 04-11-16, 08:50 PM
SoCalISF
SoCalISF's Avatar
Charge the battery and test it properly. You are putting the cart before the horse.
Old 04-11-16, 09:08 PM
NSXGuy
NSXGuy's Avatar
Can't. Stuck in the parking parking garage at my office building. Can't move it until it gets towed somewhere.
If it was the battery, shouldn't have been able to jump it?
Old 04-11-16, 09:15 PM
SoCalISF
SoCalISF's Avatar
Negative. Not in all cases. If a battery has one or more cells growing sulphates between the plates, it can effectively reduce the voltage by 2 volts per cell. Even if the battery is not sulphated, yet allowed to sit for an extended period of time, the voltage can drop significantly. Enough to kick juice out to allow the gauges and dash to light up with 'key on', but not enough to light the starter, even a reduction gear equipped one.
Old 04-11-16, 09:16 PM
SoCalISF
SoCalISF's Avatar
How many miles on that car?
Old 04-11-16, 09:27 PM
NSXGuy
NSXGuy's Avatar
48k miles.
Quick Reply: My car won't start
