Will RCF wheels fit on ISF with swift springs?
OK guys, I want to apologize for asking another "will it fit" thread but.. I recently hit a curb and ripped my front wheel off the hub... In doing so I messed up my wheels pretty bad. Turns out the insurance will cover other wheels as long as they are Lexus. So I was thinking about getting the RCF blade style wheels on my isf but I was concerned about rubbing in the rear. The tire specs are
Front Wheels: 19x9 with 50 offset
Back Wheels: 19x10 with 41 offset
Front Tires: Michellen Pilot Sport 255/35/19
Read Tires: Michelen Pilot Sport 275/35/19
I know a guy who has them and had to roll his rear fenders to make them fit on stock suspension.. If I'm on swift springs and roll my rear fenders, will the extra drop make a difference? and or does anyone have the same spec wheels?
Thanks so much and.. Sorry again...
Maybe you want to read this thread:
https://www.clublexus.com/forums/is-...on-an-isf.html
I have RCF wheels with 255/35 and 295/30, so rear tires are both lower and wider than the stock RCF tires. I have no issues in front and I need to roll the rear fenders. I will rub if I go over a speed bump too fast![Sad](https://www.clublexus.com/forums/images/smilies/sad.gif)
I luv the look, and the better handling with the wider wheels and tires.
My Post and pics are on page 5, Post #71 of the above mentioned thread:
https://www.clublexus.com/forums/is-...-an-isf-5.html
I am on stock suspension except for RRRacing LCA Bushings in front and an F-Sport rear sway bar.
Lou
Lou
