Lost air box clip--what to do?
Old 04-15-16, 06:46 PM
Jz39
Jz39's Avatar
Default Lost air box clip--what to do?
I was reading about a couple of people with AFE filters with missing air box clip(s).
I lost a clip too after putting in AFE however I don't have a broken tab and I can't be sure it wasn't the idiot tire installation guy that was messing with my air box for a courtesy check that might have screwed it up. I didn't notice any significant difference in effort closing the stock box after AFE. I guess I'll gorilla tape the second one down just to be sure.
For those of you with lost clips, what are you doing to compensate since you can't buy just the clip? Is this really an AFE issue or just a coincidence?
Old 04-16-16, 06:44 PM
Jz39
Jz39's Avatar
Wow, dealer found it on the lower engine cover. Phew. Can't believe it was still there. To those of you that have lost clips, be sure to do a thorough search.
Old 04-16-16, 08:46 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,066 Likes on 2,463 Posts
And what advantage does the AFE filter have over stock? Besides breaking the OEM airbox?
Old 04-16-16, 09:09 PM
JDMV8
JDMV8's Avatar
I was about to say if you lost the clips, sell the car...
There are $3 remedies if you lose the clips, hope is never lost
Old 04-17-16, 07:16 AM
Jz39
Jz39's Avatar
The placebo effect is a real thing and considering there is not much else on the car that I would feel comfortable touching, this is my form of wrenching
I honestly I don't think it is the filter though--nothing seemed to not fit properly--I'm pretty sure it was the tire shop courtesy check of the air box and not reselling it correctly after I told them that they didn't need to be under the hood to change the tires!
Old 04-17-16, 09:05 AM
STLblueF
STLblueF's Avatar
I was missing one as well but my car had the stock paper filter. It seems to be pretty common that these break if the techs aren't careful with them. The tab that holds the clip on my airbox was actually broken, so even if I had another clip it wouldn't hold.
I got extremely lucky checking ebay for over a year and one finally popped up for sale that I snagged for a very good price. That probably doesn't help, but for others with the same problem, I would imagine once RR racing is selling their tuned intake, more airboxes will show up for sale.
Old 04-17-16, 03:53 PM
Jz39
Jz39's Avatar
LOL! There will be a glut of 80$ air box clips on eBay!
Old 04-20-16, 01:50 PM
kzlflash
kzlflash's Avatar
That's what I'm waiting for
Or else I'll have to get their intake and tune.
Right now my airbox is missing both clips, with one tab completely broken.
Old 04-20-16, 04:52 PM
Joe Z
Joe Z's Avatar
Received 1,064 Likes on 586 Posts
The Tabs on the bottom ? One looks different than the other..
Visually it could look broken, but likely not.. (unless you see the whole chunk missing)
Joe Z
Old 04-21-16, 01:25 PM
kzlflash
kzlflash's Avatar
Joe Z
The squarish block that the metal clip snaps against (to hold the top of the airbox together). The tab is essentially snapped, and moves around like a door hinge, and has that look when you bend plastic, and it turns white on the bend points.
Old 04-21-16, 01:40 PM
Jz39
Jz39's Avatar
I've locked mine down with a couple strips of Gorilla tape for good measure.
Old 04-21-16, 02:09 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
125k miles, 8 years old, OEM filters and my airbox looks just like new. There's a note about this in my signature...
Few deliver the advertised claims. Many are actually worse than stock.
Old 04-21-16, 07:29 PM
Orthodoks
Orthodoks's Avatar
I'm glad I'm not the only one I guess. I wonder if extended warranty covers this since its not a wearable part. Otherwise I'll be looking for an air box as well.
Update:
This is covered by the Platinum Extended warranty. Lexus will order you a whole air cleaner assembly at $804.
jdmek998
IS F (2008-2014)
04-04-20 05:50 AM
prowler97
09-16-13 12:09 PM
Bliggity
GX - 1st Gen (2003-2009)
12-30-09 11:58 PM
Kbach
02-15-04 01:18 PM
Lextreme
Performance & Maintenance
08-18-03 11:07 AM
Quick Reply: Lost air box clip--what to do?
