Borla exhaust help!!
Old 04-27-16, 10:37 PM
  #31
jadeboy
jadeboy's Avatar
Originally Posted by Diesel350
Do you have primary cats or are you catless?
Catless now.. there is no value to add a header and not remove the cat.
Old 04-28-16, 07:32 AM
  #32
Diesel350
Diesel350's Avatar
I would think that adding the cats would reduce your drone.
Old 04-28-16, 09:30 AM
  #33
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
Of course there is. Running Hi-Flows, I figure I'm losing 7 to 10RWHP. But, IMHO, it's the environmentally responsible thing to do. I am not a real green guy, and I have full boltons, but running cats just makes sense to me.
Lou
Old 04-28-16, 09:54 AM
  #34
Rickna
Rickna's Avatar
Lou
I agree Lou. I've been behind vehicles with bad/no cats. Breathing in that s***t is horrible.
Old 04-28-16, 10:44 PM
  #35
jadeboy
jadeboy's Avatar
Lou
I did that in my 2007 IS 350.. Had PPE header, could never solve CEL and VSC issues (there a long thread in the IS 2nd-Generation) due to a lack of O2 sim at that time. I installed PPE high flow cat.. it solves the CEL and VSC problems but it also crippled the car to feeling like back to stock.. the awesome sound was gone.. the power was gone.. if I knew that the high flow would do that.. I would have never install header in the first place.
Old 04-29-16, 03:59 AM
  #36
FFM
FFM's Avatar
They make weld on helmholtz chambers FYI. Order up the exhaust you want, purchase helmholtz, and have a weld shop weld it on before the install.
Old 06-17-16, 01:38 AM
  #37
mcauley
mcauley's Avatar
Default Sound valve
I have the Borla exhaust and the drown between 1000rpm and 1800rpm is too much. I plugged the lower to pipes and the drown stopped.
If I put two exhaust valves on will it do any harm to the exhaust?
Old 06-17-16, 07:34 AM
  #38
isfdave86
isfdave86's Avatar
The secondary cat that is removed with the Borla system won't throw a CEL, I hope?
I ask because I have Borla on the way and opted to not get a high flow cat replacement
Old 06-17-16, 08:19 AM
  #39
jadeboy
jadeboy's Avatar
If I put to exhaust valves on will it do any harm to the exhaust?
How/What did you plugged with?
Old 06-17-16, 10:49 AM
  #40
MileHIFcar
MileHIFcar's Avatar
No the absence of the secondary cats with the Borla will not throw a CEL
Old 06-17-16, 02:04 PM
  #41
mcauley
mcauley's Avatar
Ha I turned two prices of wood to fit tight enough that it didn't blow out. I only went about 2 miles then Cq it.
Old 06-17-16, 02:10 PM
  #42
ISFTOMMY
ISFTOMMY's Avatar
i just did a muffler delete its not to loud the drone is not bad at all
Old 06-21-16, 01:22 PM
  #43
mcauley
mcauley's Avatar
Has anyone a picture of what the inside of the Borla back boxes looks like?
Old 06-21-16, 04:15 PM
  #44
Rickna
Rickna's Avatar
Here ya go-
Old 06-21-16, 07:36 PM
  #45
Fivepoint0
Fivepoint0's Avatar
are you talking about inside the rear mufflers?
Quick Reply: Borla exhaust help!!
