Squeaking Suspension
When going over large bumps and dips I'm hearing a very high pitched squeaking noise coming from the rear end. Over small bumps I hear nothing, it's only the large bumps where I hear the squeak. Anyone else have a similar problem or have any advice where to start troubleshooting?
Most likely it's a bushing.. Get under there and spray some silicone spray on a couple bushings at a time and then go over a bump.. One you find the culprit either smother it in spray or (preferred) get some actual lube on the bushing.
lowdownsc
Suspension and Brakes
03-16-13 01:33 AM
