Stoptech street pad users chime in
Old 05-03-16, 07:09 PM
  #31
Fsport2UR
Fsport2UR's Avatar
Originally Posted by itsmejon
I should add I've taken them out cleaned all the lube off the back and applied new lube then reinstalled them as well but seems to come back.
Where and how did you lube.
Old 05-03-16, 07:52 PM
  #32
RSXiMUS
RSXiMUS's Avatar
Had my Stoptech pads for a couple months now and I have yet to hear a squeak from them. I did replace my rotors at the same time with Raybestos Advanced Tech and did the bed in procedure to the dot.
Old 05-03-16, 10:28 PM
  #33
itsmejon
itsmejon's Avatar
I didn't experience any noise until I had the pads a while. I thought they needed to be replaced but still plenty of life on them left.
Old 05-04-16, 08:35 AM
  #34
flowrider
flowrider's Avatar
Received 1,933 Likes on 1,362 Posts
It's all explained here:
https://www.clublexus.com/forums/is-...rake-pads.html
This is the DIY In used
Lou
Old 05-04-16, 09:19 AM
  #35
Fsport2UR
Fsport2UR's Avatar
Lou
I am not asking for directions on how to do it. I know how to DIY. As I have mentioned previously in this thread, I have gone ~5k miles on stoptech pads with no issues of squealing at all. I am asking how the guy with the problem lubed his shims...because I believe he did it incorrectly.
Old 05-04-16, 03:32 PM
  #36
itsmejon
itsmejon's Avatar
Between the shim and the pad?
Old 05-04-16, 03:40 PM
  #37
jlam86
jlam86's Avatar
I too did it between the shim and pad and a thin coat on the layer in contact with the piston.
Old 05-04-16, 08:28 PM
  #38
Fsport2UR
Fsport2UR's Avatar
And that is not correct and likely the cause of all your squealing. The lube/grease goes in between the piston and shim.
I stated earlier, the Lexus dealer that previously did the brake job applied the grease incorrectly, they greased in between the shim and pad, and no grease between the shim and piston...and my car squealed like a pig on every low speed stop.
Old 05-05-16, 11:00 AM
  #39
jlam86
jlam86's Avatar
Great! Thanks for the tip. I will give that a shot when I have a few minutes
I did it on both sides. Piston side and on the back of the pad
Old 05-05-16, 11:12 AM
  #40
LOWFAST
LOWFAST's Avatar
Originally Posted by fsport2ur
and that is not correct and likely the cause of all your squealing. the lube/grease goes in between the piston and shim.
^^^^ bingo!
Old 05-05-16, 01:05 PM
  #41
flowrider
flowrider's Avatar
^^^^I did it as explained in the DIY I attached.
Lou
Attached Thumbnails Stoptech street pad users chime in-picture_php_pictureid_3579_4b131db3d091b5ef6721c165b922ce6a8313ff87.jpg
Old 05-05-16, 01:58 PM
  #42
itsmejon
itsmejon's Avatar
So put lube on both sides of the Shim? I didn't have any noise issues until later down the road.
Old 05-07-16, 04:04 PM
  #43
jlam86
jlam86's Avatar
Lou
did u also apply a thin layer to the side contacting the piston?
Old 05-07-16, 05:09 PM
  #44
flowrider
flowrider's Avatar
^^^^No, I did not. I reused my old shims and cleaned them well with brake cleaner.
Lou
Old 05-07-16, 05:25 PM
  #45
jlam86
jlam86's Avatar
Lou
lol! so I have one fellow telling me I am doing it wrong by putting it between shim and back of pad.
you're recommending me apply it to put it between the shim and back of pad only.
lol the power of the internet hahaha
Quick Reply: Stoptech street pad users chime in
