who has had coolant leak around valley plate?
#181
just had mine valley leak fixed, parts did not cost much but did have to replace 4 injector connectors. 2 Orings and the Toyota/lexus (gray fipg) instead of the black silicon which might leak again over time.
#182
I am checking with them to make sure they used a different sealant. Thanks
#184
I just confirmed with them. Interesting they say that the gray fipg is what they use on non gasket seals. So this should have been used from the factory.
Matt
Matt
#186
Tech Info Resource
Neither gray nor black is correct. It's really bad to assume you know more about sealants than ThreeBond. ThreeBond 1282B Toyota Part No.: 08826-00100 is the right sealant and is about $85 a tube. Definitely not cheap, and not in stock at any dealership.
s2kjer (01-03-18)
#188
That's a good point. Make sure you look at the car when it's completely cold. Don't tell the dealership you're coming or they might run the engine either to detail it or move it to a different spot. They might also top off the coolant if they're sleezy and know there's an issue. When you get to the dealership walk over to the car yourself; don't have them drive it over. The car must be cold for the coolant level to be checked properly as stated above.
#190
So a quick update on my valley plate repair. So not sure exactly what sealant they used, but I can inquire. They may need to take it apart though...
I got the car back and everything seemed well, but when I drove it home on Friday I smelled gas. I thought it was just some spilled left over fuel from taking everything apart, but I started it up again that night and still smelled it. So I took it back over Saturday morning and the tech did a quick look over and did not see any visible fuel leaks. I left it there and they are going to check it out tomorrow.
I am a little concerned that they will need to take it all apart again. However this should be on them, right? The tech said the only fuel line that was removed under the valley plate was torqued down to spec, but if there was something on the surface of the connection that could be causing the leak.
The ELF has already been done on my car so it probably isnt that.
Matt
Matt
#191
Another quick update. The tech is thinking the fuel smell is coming from the intake manifold gaskets. Going to replace those to see if the air/fuel mixture from the secondary injectors is seeping out. Also going to check all fuel line connections once the intake manifold is off.
Matt
Matt
#192
you should be able to tell from the invoice you received that part number should match the one posted above
not sure why the fuel smell be coming from the intake gasket, that should be replaced after sealing the valley plate. hope they didnt stretch anything too far and created a little leak.
#193
Pretty sure they did exactly that, SlowAsF...
However, my car has quite a few miles on it so makes sense. Two fuel related lines need replaced. Part numbers below. Those are being put on tomorrow as well as the intake manifold gaskets, since they already ordered them. Hopefully I am back up and running tomorrow sometime. However the features of this RC loaner have me spoiled![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
23274-38020 – Fuel hose part of the fuel pressure relief system
23829-38050 – Hose for the evap system
#195
Does anyone have a rough guideline on the whole process? Dealer quoted me $2600 at 8-9 hours with parts, so I'm gonna have a friend help me out.
And while all the intake manifold is off, do plugs and head gasket?
