who has had coolant leak around valley plate?
#601
Tech Info Resource
The service manual still says 1282B for everything including the latest models with a 2UR in them (LC500 & RC F). I am sure there are shops using 103 sealant, and it might work just fine too, but it's not listed as the sealant to use in the service manual. It's quite a bit cheaper for sure.
If there's anyone in Atlanta who needs this sealant for this repair, let me know. It surely doesn't take the entire tube to do this task; I have a lot left over.
#602
I see, there must be a way to double-triple the life expectancy of this situation before it happens again. It is what it is for now until someone finds a much better remedy.
#603
Tech Info Resource
Bevel the edge and TIG it in place. Pressure check before assembly and fix any pinholes. Done forever.
LSpho (12-06-20)
#606
Received 1,063 Likes
Checking in:
Dropped it off at Lexus of Pleasanton. Unfortunately they washed my car, added swirls and probably took off my acrylic sealant =\ Anyone know if these car washes will cause damage to my wheels?
Anyways 1200$ would be out of pocket if they cannot get lexus corporate to issue out a goodwill repair for the holidays or if they won't discount it/aid in payment. I'm assuming they'll use the sealant they've always been using.
Anyone recently have prices of good independent shops or if any update in sealant type been used?
As stated by Lobuxracer there is only one sealant by the book..!!
What matters the most is the prep and process
What we know.. The "black gold" product is made by ThreeBond International Inc.
Seal Packing 1282B
Toyota / Lexus Part Number 08826-00100
Joe Z
Yri (12-06-20)
#607
Tech Info Resource
Yes indeed, and the nozzle for the 1282B won't even screw on the 103. It's way bigger.
#608
Tech Info Resource
Well looks like my valley plate is starting to seep on my 2008 F. I started losing some coolant about 6-8 months ago. Reservoir bottle gets low at about 2-3 months so its minor right now. I have about 153k miles, I am the 3rd owner. Vehicle has been maintained at Lexus its whole life and does not appear to have ever been done. I got a good run out of the factory sealant.
Justind27 (12-16-20)
#610
Update: The dealer I dropped my car off to says corporate is willing to give some financial aid. I will be paying around 800 instead of 1400. Also they broke an evap hose so I'll be waiting a little longer for that part to come in.
What is mentioned is that the original seal from factory is uneven which can contribute to the leak; they will by hand ensure that the same problem does not happen. They mention the valley plates they have done on other 1ur/2ur cars have not had any issues thus far -knock on wood-
#611
Tech Info Resource
It's very difficult to say exactly why the valley plate fails. It's extremely unlikely it's an assembly fault. If it were, they would have sorted it out by now.
#612
Got the leaking upper tank replacement yesterday, I would like to recommend for those that had the elf recall work and were told “new radiator” to check, I would have to go back on my paperwork to see but I doubt mine was replaced with as much stuff was impacted. I’m much more pleased with the koyo radiator over the mishi i was fooling around with years back, that almost went in but decided to wait for the stock to fail. Time to see if my valley is leaking since I’ve decided to change the wp which I’ve had since the beginning jic it went out
#613
Best way to tell if you have the new radiator design is the small overflow nipple that exits into the overflow hose into plastic tank.
The original version was much smaller than this one below and broke / breaks off easily..
Although the newer versions are also blowing the seals..
Joe Z
Joe Z
#614
Update: Paid 810$ instead of 1400$ due to corporate Lexus goodwill financial help. It's done at 78k~ (no idea when it first started) the leak was enough to drop from full to low in the coolant reservoir within a matter of days. Did not ever notice it drop below the low point or over heat. Hopefully this helps others with price points and statistics.
Elf recall and radiator issues? interesting, guess my future one will be a koyo or mishi if any problem arises.
#615
ELF Recall relates to the fuel pressure sensor gasket :CERTAIN 2008 - 2011 MY IS-F (2UR- GSE)
https://static.nhtsa.gov/odi/rcl/201...4V647-5234.pdf
Joe Z
