Alignment Specs after spring install
05-05-16, 05:43 PM
05-05-16, 06:05 PM
That's a lot of camber from just a mild drop from the swift springs..or is it just me?
05-05-16, 06:45 PM
You will be fine with these specs. For the street - your camber is fine - should not cause premature tire wear.
05-05-16, 08:35 PM
Tech Info Resource
Quote:
Originally Posted by
Vervish
+1. Anything under 2.5 and nothing to worry about.
05-05-16, 08:43 PM
The camber looks fine. It's also not really as much camber as it is toe that causes premature wear.
05-05-16, 08:50 PM
Yeah that is fine. Toe kills tires and camber isn't too bad. Just better to take corners harder lol
05-06-16, 06:51 AM
lobuxracer
Toe should be in on the rear? and 0 on front?
05-06-16, 01:56 PM
VicTornin
A bit of toe in on rear doesn't hurt. It will help you get more traction for rears
05-09-16, 12:27 PM
jspecvtec
since you're like down the street from me, where did you get your F aligned? I'm on stock springs.
etct3189
RX - 3rd Gen (2010-2015)
05-20-18 06:57 AM
Trendzero
Suspension and Brakes
03-13-12 06:24 PM
SPEED&ECO.
01-28-07 02:40 PM
SKYTECH
06-04-06 03:52 AM
One HoT
11-07-02 02:20 AM
