19x9.5 +43 5x114 front and rear.....will it work without any issues?
just wondering if this specs will fit in the front and rear without any issues....
TIA
TIA
Yeah, I second Kelvin. The front has plenty more room, and +43 is entirely safe. With regards to the rear, I'd say you're spot on there. You most likely won't need camber. What tires were you planning to run with them?
You might want to roll your fenders and you should be good to go then!
-Josh
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
Did you have to do anything to either front or rears to make it work? I know the fronts have a little bit more clearance and can house more aggressive offset wheels. I've always recommended more on the conservative side when helping friends pick out wheels for their Fs, but I know the aggressiveness can be had in the fronts with sufficient modification using camber arms and maybe some increasing of height with coilovers.
people love to ask questions on a question thread which then helps out everyone including OP when they answer more than one question. just my 2 cents.
anyways moving on with the OPs question. you should be fine without any problems at stock height, i am running 8.5 45 Front with 245/35/19 and 9.5 42 rear with 275/30/19
Ltaboso
IS F (2008-2014)
11-02-15 04:58 PM
laxton
IS - 1st Gen (2001-2005)
02-08-13 02:40 AM
