Brake noise at 18k?
Brake noise at 18k?
Hi guys,
I got my 2011 ISF with 17k miles. About a month ago it started to make noise under light braking. No noise under heavy braking. I know the ISF go through brake and tires like crazy but at 18k miles? I know the previous owner was a pretty conservative driver. What been your experiences with brake change intervals?
What pads and rotors do you guys recommend for a new set? Thanks!!
Obviously, brake pad & rotor change intervals will vary based on your driving habits, but I'd be surprised if your rotors are ready for replacement.. I'm still on my OEM rotors at 43K, and that includes three track days.
If they're OEM pads, some low speed noise is not uncommon. Measure the pad thickness to see if there's still life in them. If so, a good cleaning, plus a re-lube with the OEM Brembo goop or a copper-based anti-seize should help with the noise.
Replacement parts will also depend on your driving habits.. If you're not looking for increased performance or weight savings, the OEM Brembo rotors are probably the best bang for your buck, especially if you shop around for deals (Amazon & eBay often have decent deals).
There are tons of pad options depending on how much you want to spend & what kind of performance & other attributes you're looking for (like noise/dust). If you only do street driving, & don't mind giving up a some initial bite, I recommend the Project Mu NS400.. They're somewhat pricey, but in my experience they've been completely silent and virtually dust free.
I'm currently running the Project Mu HC+800 since I need something more suited for track days. I like these pads too. They're quiet once properly bedded, and they can take some pretty good abuse. The only downside is they're pretty dusty with aggressive use, but that's something you're probably going to get with just about any track oriented pad.
-Mike
-Mike
Talked with my lexus tech about this.
A few things.
1. high friction break pads will cause noise from time to time. Mine do them as well and im clocking 17,500 miles
2. They could be extremely dirty. In this case obviously clean, but go about 40 and hit the breaks hard, dont do it so you break traction but just enough to scrub all the dirt, grime and build up. This should do the trick.
3. break cleaner always works as well but doesnt last long.
Hope this helped.
A few things.
Hope this helped.
The high pitch squeal you are hearing is actually caused by metal to metal vibration, and in a lot of cases it is not from the pad on rotor contact. I believe it to be from the shim and piston contact, or a contact that holds the pad. Apply grease on the contact areas of the pad to where it is seated, and more importantly grease the area of the shim that contacts the piston. I had squealing at low speed braking when I bought my car and just couldn't stand it anymore, I took out the rear pads and the Lexus tech greased the area between the shim and pad which is incorrect; and he should of greased between the shim and piston. This area is where a lot of vibration takes place because the pad+shim itself is free moving and not necessarily stuck to the piston at all times, and if there is little to no grease between these two parts, you can get significant metal to metal vibration. A ton of people do not grease their pads correctly or don't know how.
Keep in mind also that these are Brembo brakes. Brembo outlines a specific grease for their brakes, but it is very expensive. I also believe Lexus dealerships are unaware and don't carry or use this type of grease. Lobux recommended a copper based variant. I used that and it works. My brakes no longer make a peep at low speed.
INCORRECT
CORRECT
INCORRECT
CORRECT
INCORRECT
CORRECT
INCORRECT
CORRECT
Like many of you, I have a high pitched squeal at very low-speed braking (stop and go traffic and stop signs in neighborhoods). Mine is focused on the passenger-rear for some reason..
Holy crap.. Thanks for this. I've taken my car 3 times to the dealer and they kept telling me it was 'an aspect of performance brakes'. Do you happen to know what the part number or what the grease is called from brembo? Also, how often are you supposed to apply the grease?
I asked this question of Forum Sponsor SpeedFreaks and received the following reply:
The recommend the product pictured below.
This is not what I used when I did my brakes. I used regular Permatex brake caliper lube. I'll know better next time But I do not have noise. I have Ferodo DS2500 pads in front and ProjectMu TYPE HC+ 800 pads in back. I also have slotted rotors in front, stock rotors in back. I absolutely luv my brake system
Lou
There are a couple surfaces that need to be lubricated by a dry lubricant after they are cleaned of rust and debris: One is the small contact area between the caliper housing and the brake pad edge guides, the other is the back of the shim where the piston contacts the shim. Both should have a thin layer applied. In the odd case where the shim is sliding on the backing plate of the pad, you can place something there as well.. But the shim should not be loose, it should be static and typically the backing plate of the pad is painted - which will burn off from track abuse, as will the dry lubricant. So this all applies only to street use.
Lou
- Copaslip Antiseize Assembly Compound 3471
- 3M™ Copper Anti-Seize Brake Lube 08945
https://www.clublexus.com/forums/is-...ml#post6542349
Lobuxracer recommended two. Both are copper based like the Brembo grease. You can find both on Amazon.
-Mike
I've been using this Honda part number:
08798-9027
Which is "Brembo Grease" - It comes in a toothpaste sized container - It looks and feels as tacky / copper as the one supplied with OEM IS-F pads.
Anyone else tried this part number?
Cost me $40 bucks though but I figured they give you a lot and it will last me multiple changes + more
08798-9027
Well, the proper way to lube the shims seems to be all over the place
The Grease mentioned in the post above seems to be unique to the ISF:
http://www.lexuspartsnow.com/parts/l...998-94072.html
Lou
Lou
Response from Speed Freaks in another thread:
Lou
Let me preface this by saying I never use shims on any of my vehicles but I have always been taught to apply the anti-squeel between the shim and the backplate if you're going to use it. I don't think there is any "problem" with also putting on the backside of the shim that comes in contact with the pistons other than it making a little bit of a mess.
-Matt M.
-Matt M.
