High Altitude + Tune = Think again (bye KCLV)
Old 05-25-16, 10:51 AM
  #31
liquidtek
liquidtek's Avatar
Originally Posted by MpKSonic
Why would they find a middle ground? Wouldn't it lead to the same results currently being addressed in this thread? Why not have multiple maps and users can run whatever map suits them best and gives them the most power the safest.
My house in Colorado Springs sits at 6600', so I would never consider buying a blanket tune that works best in elevations that I will probably never see.
If they don't want to spend the time to supply to the above guesstimated %5 of us up in this clean, crisp air, then I wouldn't bother with a tune. I completely understand that it's a business decision as RRR doesn't want to lose money, but if it's as simple as viewing data logs and adjusting numbers to prevent knock, I hope they cater to us.
I went and did some datalogging last night with some WOT 4th gear pulls and sent my files to Frank at TTFS. He's going to take a look at them today. I agree it seems like we're the minority when it comes to the 5%ers at altitude. I get they don't have easy access to places to test high altitude so now we're the guinea pigs for the R&D. Oh well, I'm going to ask TTFS if I can have one of their new handheld data loggers when they come available to continue development for us. Will update as new things develop.
Old 05-25-16, 11:13 AM
  #32
idoke1
idoke1's Avatar
^^Looking good liquidtek. Keep us posted
Old 05-26-16, 02:29 AM
  #33
RSXiMUS
RSXiMUS's Avatar
Found the cure to my KCLV woes..
Boom, Octanium baby...
Poured in half a can and filled her up with fresh Chevron 91.
Went out and did 3 pulls, KCLV shot from 17.2 to over 20 right away.
Looks like the tune doesn't like our crappy CA 91 gas.
Old 05-26-16, 12:33 PM
  #34
semnosNSX
semnosNSX's Avatar
That's awesome! So now everyone with a tune just needs to by stock in Octanium and we will be good to go! What's the point of a tune if you have to put octane booster In every time you fill up? Man, just seems like there are still a lot of bugs to be worked out before I plop down $700.
Old 05-26-16, 12:54 PM
  #35
Bigjon3475
Bigjon3475's Avatar
No, you could install a water/meth injection system and then you wouldn't need to add anything to the gas. You'd get significantly higher octane ratings with the injection system anyways and in the long run it would probably be cheaper. Plus, you'd already be prepped for the supercharger system without intercooler.
Old 05-27-16, 06:45 AM
  #36
SubOrbital
SubOrbital's Avatar
So that one day your meth injection fails and your high-strung tune, which relies on the meth, can grenade your engine. Yeah great idea. "Run a meth injection system instead of octane booster" hurrdurr. Are you series?
The man is right; there's no reason to buy tunes if they're so unrefined that people are seeing knock correction in daily use.
Old 05-27-16, 09:17 AM
  #37
RSXiMUS
RSXiMUS's Avatar
I think people who have access to 93 octane at lower altitudes will benefit the most from the tune, for those at high altitude it looks like no amount of increase in octane will raise their KCLV levels unless a re-tune was made specifically for them..
For us CA peeps, looks like in order to maintain the KCLV levels over 20 reliably, you might need to add a can of octane booster every fill up. What's strange is I was able to bring KCLV levels over 20 without any octane booster a month ago, maybe I got a bad tank of gas recently?
Old 05-27-16, 09:57 AM
  #38
semnosNSX
semnosNSX's Avatar
That's my point. I'm not trying to bad mouth RR-Racing because I appreciate their efforts in this endeavor. However, they can't create a "tune" that works in one particular environment (those at sea level with access to 93 octane fuel) and try to sell/market it to the rest of the world as a one size fits most tune with incredible gains. I have read through all the tuning threads on here and it just seems so hit or miss as to if the tune actually works. If I have my car tuned, I shouldn't have to worry about putting octane booster In at every fill up... or have to worry about constantly hooking up to techstream to verify my KCLV levels to make sure my tune is working. Just my .02.
Old 05-27-16, 10:25 AM
  #39
RRRacing
Sponsor
CL Vendor - Starter
RRRacing's Avatar
Received 1,416 Likes on 648 Posts
The tune is relatively new. Once we get a sense for how the cars behave in different regions, we can simply modify the tune a bit and send the user the update, and others will benefit from that going forward. So right now we are working on a tune that will be less sensitive to lower octane levels.
Rafi
__________________
We Engineer Track Proven Upgrades For Your Lexus!
SUPERCHARGERS : ECU TUNING : SUSPENSION : EXHAUST : PPE MASTER DEALER
Online Store: www.RR-Racing.com
Email: Contact@RR-Racing.com
Phone: 484-756-1777
Facebook : Youtube
Old 05-27-16, 11:50 AM
  #40
STANC36
STANC36's Avatar
Does the tune work on European cars as well? Would be interested to see what happens over here. We got 95, 98 and at some gas stations 100 or 102 octane. I'm at an altitude of 1700ft
Old 05-27-16, 01:23 PM
  #41
idoke1
idoke1's Avatar
that's my secret to keeping my KCLV in the 20s
Old 05-27-16, 02:11 PM
  #42
5280ISF
5280ISF's Avatar
That stuff is not cheap. Is it better than Torco?
The VP website shows not safe for O2 sensors and Cats??
http://www.vpracingfuels.com/index.h...ct&ID=29421785
May not matter to those with straight pipes...
Old 05-27-16, 04:22 PM
  #43
Bigjon3475
Bigjon3475's Avatar
You're not running 40 psi of boost on the car. When you run out of water/meth the car goes back to the exact same way it was before... The way it is now... I appreciate the hyperbole though.
Old 05-27-16, 07:09 PM
  #44
tas02
tas02's Avatar
I'm good with dumping a in a half can of VP Octanium before a day at the drag strip, track or dyno.
Low KCLVs are actually proof that "your high strung tune" won't "grenade your engne".
Old 05-30-16, 12:53 PM
  #45
MileHIFcar
MileHIFcar's Avatar
Update:
Liquidtek pulled the KCLV values of a local member here with a stock tune (like me) and his numbers were also low they were 11.5/13 IIRC............
So what does that say about KCLV numbers when they are low with a stock tune?!?! My numbers were considerably higher when he pulled mine at 17.8/19.5.........
Opinions?
Quick Reply: High Altitude + Tune = Think again (bye KCLV)
