GSF wheels on ISF
#76
^^^^The front (gap as you call it) is the same as stock wheel/tire combo).. The 225/40/19 stock size and the 255/35/19 tire you are now running have the same OD, 26". The stock RCF tires you are running in the rear are 275/35/19 and are .6" larger in OD than stock, 26.6" vs 26.0".
I am running 255/35/19 in front and noticing no additional gap. I am happy with the extra width of the wheel, handling and more flush with the fender line. I am running 295/30/19 in back, same OD as stock, and did have lots of rubbing until I rolled the rear fenders flat. I now have occasional rubbing when I take a bump going to fast or when I have two people in the back seat. Otherwise no issues.
Lou
Lou
s2kjer (08-27-17)
#78
#84
Does anyone know what the EXACT weight of the GSF & ISF wheels are? I'm assuming the fronts would be lighter than the rears (due to width)
#85
The RCF wheels are similar (dimensions) to the GSF wheels and have been weighed by me (the standard wheel) and another forum member (polished wheel) the results were:
Standard wheels are:
9" = 25.5 lbs
10" = 28.0 lbs
And the Polished wheels are:
9" = 26.6 lbs
10" = 28.7 lbs
I would assume the GSF wheels are pretty close to the RCF polished wheel.
Lou
9" = 25.5 lbs
10" = 28.0 lbs
9" = 26.6 lbs
10" = 28.7 lbs
Lou
#87
Had a lot of people reach out about fitment from another thread so thought I'd bump this thread.
- The rear will indeed require a roll
- As Lou mentioned above, did not modify front fenders. I am actually running a 12mm spacer to sit flush and match the rear fitment.
- Tires are Indy 500: 255/35 front and 285/30 rear
- No rubbing whatsoever
Well worth it!!
Well worth it!!
The following 6 users liked this post by YoungPNW:
2011ISFNY (06-20-20),
lobuxracer (06-20-20),
lorenr (06-19-20),
Positron (06-19-20),
Quadrphnia (06-20-20),
and 1 others liked this post.
masboy
CL of Southern California
12
08-21-17 04:49 PM
brtnrdr1x
Wheels and Tires Classifieds
18
04-08-10 10:57 AM
hwy1isf
24
03-22-10 09:30 PM
