DIY: Lexus ISF/ISx50 Cluster Removal
Hey CL,
Wanted to go ahead and make a DIY thread with a quick overview of what you need to tackle this job. This is mainly for those who wants to swap out their clusters, customize or repair burnt LED's, concealing certain lights such as AFS or TPMS, or whatever you desire. Video of complete DIY provided at the bottom. Lets get started!
Tools needed:
-Phillips Screw Driver
-Plastic Trim Tool
Time till completion:
-Roughly 5 minutes to remove and/or reinstall.
Quick steps:
-Turn on and off the vehicle as it may help in the process of removing parts.
-Turn steering wheel left and/or right while car is on.
-Remove steering column cover using a phillips screw driver. ( 2 screws )
-Push upper column cover up.
-Remove panel cover on outer left side of dashboard. ( trim tool )
-Pull down kick panel with your hands carefully. ( few yellow tabs )
-Allow kick panel to hang freely.
-Remove ( 2 plastic screws ) cluster trim upper area.
-Remove ( 2 screws ) cluster trim lower area.
-Pull out trim slowly and then move it to the right carefully.
-Push and pry upper cluster tabs ( gray and brown ) on both sides and pull cluster forward.
-Unpin 2 harness clips from the cluster and pull cluster to the side.
Reinstall everything in opposite order.
I do not take any responsibilities for any damages as this is just a quick guide for those who are visual learners or want to see it first hand to build confidence in taking this job yourself. Thank you for your time and subscribe to my YouTube channel: KANTSTANDLAM GARAGE for more DIYs.
Tools needed:
-Plastic Trim Tool
Quick steps:
Your videos are very helpful and educational. They help in so many ways. I usually tackle items like this without any thought and can figure it out, but your videos help with understanding what needs to be done before we even think about doing it. "Failing to prepare, is preparing to fail."
1JZPWRD
Performance & Maintenance
149
06-21-17 10:17 PM
