PCV valve
Old 05-27-16, 07:58 PM
lukeisf11
lukeisf11's Avatar
Default PCV valve
Does anyone have a photo or diagram of where the Pcv valve is located on a 2008 ifs and how hard it would be to change
Old 05-27-16, 08:45 PM
flowrider
flowrider's Avatar
Received 1,903 Likes on 1,342 Posts
you should be able to find it using this thread:
https://www.clublexus.com/forums/is-...separator.html
Welcome to CL
Lou
Old 05-28-16, 03:21 AM
idoke1
idoke1's Avatar
I'm pretty sure if you need to change the pcv, you will need to remove the intake manifold.
Old 05-28-16, 06:58 PM
lukeisf11
lukeisf11's Avatar
Default Picture or diagram of Pcv valve
Can someone point out where exactly the Pcv valve is or have a diagram that shows a location on a Lexus isf
Old 05-28-16, 08:12 PM
tas02
tas02's Avatar
The F has a pcv hose, from the valve cover to the intake manifold.
There's no pcv valve.
Old 05-28-16, 08:15 PM
tas02
tas02's Avatar
And welcome to CL, lukeisf11.
Old 05-29-16, 06:33 AM
flowrider
flowrider's Avatar
http://www.ebay.com/sch/i.html?_from...valve&_sacat=0
Lou
Old 05-29-16, 06:45 AM
mikersoft
mikersoft's Avatar
As Lou said, you may be able to locate it by tracing back the hose it this photo. If you don't have an A/O separator, it'll be connected directly to the intake where the host above it is.
-Mike
Old 05-29-16, 09:50 PM
I8ABMR
I8ABMR's Avatar
Im curious as to why it would need to be replaced lol
Old 05-29-16, 09:59 PM
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
The PCV valve attaches to the Separator Case
IS F pcv part # 12204-38020
12204 attaches to 12215
Joe Z
n9tkd9 (02-20-18)
Old 05-30-16, 10:24 AM
tas02
tas02's Avatar
Originally posted by me:
"... There's no pcv valve. "
I stand corrected.
Thank you Joe.
Old 05-30-16, 10:37 AM
lorenr
lorenr's Avatar
Not sure why you would need to change it.
They can be checked however. Remove the PCV valve and shake it. If it rattles it is good. If it does not rattle it may be dirty with oil and other residues. Either way, if it is removed, soak it in some throttle body cleaner to remove the residues. Evaluate it again and if it works (rattles) re-install.
Or you can simply install a new one. I try not to throw away the OEM stuff since it is usually of pretty good quality. They are a pretty simple but effective device.
Old 02-20-18, 07:17 AM
FinLIFE
FinLIFE's Avatar
Would it be a good idea to change this before installing an aos? Is it doable without removing the intake manifold?
Old 04-24-21, 12:02 AM
ChpEng
ChpEng's Avatar
Default Separator Case part# check
Joe Z
@Joe Z @illwillem can you verify the separator case is part# 12215-38020?
Most sites show a match for MY 2011 but some are showing not.
My valley plate repair is in-process, and after seeing the inside of illwillem's, I want to replace this part.
What purpose does the foam insert serve? Anyone happen to know the part number?
Immediately after intake manifold removal:
Old 04-24-21, 08:55 AM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,970 Likes on 2,403 Posts
The foam is for noise reduction only, and there's still plenty of DI noise that gets through. I wouldn't bother replacing it unless it is chunking. Mine was fine at 180k miles+ when I did my valley plate. Not sure why you'd bother with replacing the separator case. If you're worried about it (I wasn't in the slightest), rinse it with solvent and call it a day. It's not that critical, and in service it stays exceptionally clean inside from a contamination perspective.
Quick Reply: PCV valve
