oem rear wheel on the front with 255 width with a spacer. any problems???
Currently using stock oem stagger wheel set up.
19x8
19x9
want to know if i use a spacer on the back wheel, can I put it on the front?
and would a 5mm or 10mm spacer work better?
the reason I ask is that I can pick up a set of rears and would prefer to run a square setup without ahve to use 245 width across the board. I would like to use 255 on all corners (the stock size of the back tire)
thanks in advance for anyone who can help![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
ps. i saw this https://www.clublexus.com/forums/is-...the-front.html already, but it didn't really provide me with a solid answer.
I did a search of the forum but didn't find anything (if someone has a link greatly appreciated)
19x8
19x9
