Equal-length header sounds
Old 08-21-16 | 07:00 PM
  #106
IredSF's Avatar
IredSF
Originally Posted by tas02
Thanks IredSF for the 2k rpm soundclips, you da man.
Much less drone than the unequal length setup now on my car.
yeah really only at 2k, less drone than my STOCK headers!
Old 08-21-16 | 07:46 PM
  #107
MileHIFcar's Avatar
MileHIFcar
You installed simulators when you did your equal length headers?? I thought you had the RR-Tune which would negate the need for simulators
Old 08-21-16 | 09:26 PM
  #108
IredSF's Avatar
IredSF
dk on that,they have an option that's supposed to deal with the cel issue. I didn't persue that option.
Old 08-25-16 | 02:05 PM
  #109
IredSF's Avatar
IredSF
okay got the lowdown from the horses mouth as they say.
simulators conditioners not needed if you have cats installed as I do. O2 conditioners on my car were removed.
Old 08-25-16 | 02:11 PM
  #110
flowrider's Avatar
flowrider
Received 1,952 Likes on 1,374 Posts
^^^^I don't see how it would make any difference if you have cats or not with conditioners, simulators or the tune.
Lou
Old 08-25-16 | 02:14 PM
  #111
jat0223's Avatar
jat0223
Unless your car is from out of the US, after market cats don't clean the exhaust enough to not trigger a cell. If you get after market headers, you'll need a simulator/conditioner or a tune. Even if you install after market cats.
Old 08-25-16 | 02:23 PM
  #112
IredSF's Avatar
IredSF
Originally Posted by SoulFreak
IredSF, can you elaborate more on the setup? The QES drones loudly at low rpms. How did the sound inside the cabin change? Is it louder? Does it drone more or less? How does the exhaust note sound now? I heard a little rasp, it still sounds bad ***! And it looks like it pulls harder. Also, on the install! Did you have to modify anything to the exhaust? For it to bolt up. Thanks in advance!
okay can authoritatively respond now. Grounding issue resolved, o2 conditioners uninstalled and violla, car runs as good as it did first time I drove off after header install.
short answer my initial impression was CORRECT, WAY LESS DRONE, way less VIBRATION, only pure EL Header and Qes exhaust sound!
im not kidding huge difference, worth it alone simply for removal of the drone/ resonance.
now that the car is all heathy again, it's easy to tell. It's unquestionably BETTER LIKE 90% eliminated.
ill get more sound clips up now that's she's healthy.
thanks to mike @FIGS and Simon @ rr for helping remote diagnose and resolve. Really appreciated it from both of you guys. (mike u nailed it, loose ground connection in wire bundle)
hope that helps folks figure out what's best for them
for me
same power gain
el sound
drone killer
win win win
Old 08-25-16 | 02:25 PM
  #113
MileHIFcar's Avatar
MileHIFcar
Awesome to hear you got this figured out with less drone is a huge +!!!!
Old 08-25-16 | 03:04 PM
  #114
FIGS's Avatar
FIGS
The Maker
no problem
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 08-25-16 | 04:46 PM
  #115
IredSF's Avatar
IredSF
Lou
just going off direct advice I got from mike and Simon
my codes btw were unrelated to emissions control issues so it maybe that your right and unrelated. Had conditioners revmoved because
a. Unnecessary and potential for problems.
b. Rr tune suppresses cel codes for emissions issues anyway.
so just as a precaution based on advice and to avoid any potential issue just had them removed, unneeded at any rate POSSIBLY problematic.
btw for FYI dipstick solution (relocation ) was required on my el header install, for planning purposes for those thinking about going this route
Old 08-25-16 | 06:47 PM
  #116
flowrider's Avatar
flowrider
^^^^Yes, the dipstick moves back a bit from the original position.
Lou
Old 08-25-16 | 07:45 PM
  #117
tas02's Avatar
tas02
Great to hear you got your issue resolved, IredSF.
​Scheduled an appoinment for 9/13 to have my long tube el headers installed. Will be ditching the aftermarket cats at the same time, f the smell. Was going to install 'em myself next year, but after hearing how they sound I can't wait.
Old 10-27-16 | 09:36 AM
  #118
FIGS's Avatar
FIGS
The Maker
guess I forgot to also post this video here.
__________________
Old 10-27-16 | 03:04 PM
  #119
Bevansbc's Avatar
Bevansbc
Sub. Interested to see where this goes. I have been holding off on exhaust and headers, with all the new developments of the tune and supercharger etc.... Plus I am still really undecided on which way I want to go.
Old 10-27-16 | 04:04 PM
  #120
FIGS's Avatar
FIGS
The Maker
working on fabbing the rest of the exhaust in Ti to complete the sound.
__________________
Quick Reply: Equal-length header sounds
