IS F Front passenger seat removal
Good morning folks!!!! Anyone know how to remove front passenger seat? Installing VAIS unit under seat and want to relocate foot vent so in winter time I do not overheat unit.
There are 4 plastic covers on each foot on the seat. Pry those off to reveal the bolts for the seat. There are also three wire harnesses that have to be disconnected. I do d it easier to slide the seat all the way forward to get to the rear bolts then all the way back to get to the front. Tilt it back to get to the connectors. Then you should be able to maneuver it out.
That is what I will try. Either block off or deflect the air away from the unit.
If you want to get to where thd ducts connect. Pull off the Lexus door trim. Just pull up on those, they snap in and out of place. Pull lower panel under the seat belt on the B pillar, just pull towards the interior of the car. And for extra room, pull the rear Lexus door trim. You will see a wire loom running down the side of the car with white clips looping over them. Unclip those and lift the carpet from the bottom of the clip. At the front of the carpet under the glove box, there is one clip holding the carpet side wall up to the side of the kick panel area. Pull that out and you should be able to lift the carpet up and see the duct. It looks a little intimidating but the trim just snaps in and out. Removing and installing car Interiors are so easy now a days.
Edit
You will also need to unbolt the bottom of the seatbelt. I believe the bolt is the same size for the seat. There should be a gray wire connection on the wide loom that is connected to the belt. Unclip and route through the carpet.
Edit
Thanks guys. I got the VAIS installed and I tighten the **** out of the bolts. Mission successful. Another DIY in the books. Now my 5 year old can watch paw patrol while I hit some twisties....
ImpactBlue
SC- 1st Gen (1992-2000)
05-22-10 05:32 PM
