Adjustable Front Upper Control Arm
Old 07-06-16, 01:23 PM
bbong
bbong's Avatar
Default Adjustable Front Upper Control Arm
Hello,
I've been trying to find an alternative to SPC Adjustable Ball Joint. I had mine cambered at 1.8*, but these things are so hard to adjust I just left it at that, once I guess it wasn't properly tightened and it slipped to -3* during track time, I had to re-adjust it, bruised my hands as getting to the bolt is really tough. Top nuts profile is very low so my wrench would skip it if it wasn't at perfect angle, also you need to bend the wrench to get a proper angle, complete crap.
In my experience the SPC Adjustable Ball Joint is not good for me, I think it rather sucks if you constantly do track days and DD your car when you need to re-adjust your camber to be less aggressive. I know that there are adjustable upper control arms not just ball joint for IS300, but is there something similar for ISF? I know RR Racing was working on one, but I have not seen it hit the market or know a release date, does anyone know of a better alternative?
Thanks in advance!
Old 07-06-16, 02:19 PM
ISF4life
ISF4life's Avatar
Figs engineering carries it.
Old 07-06-16, 03:06 PM
bbong
bbong's Avatar
Care linking me to it? I tried combing their site and can't seem to find it.
Old 07-06-16, 03:49 PM
ISF4life
ISF4life's Avatar
http://shopfigs.com/v3/index.php?rou...ry&path=105_37
Old 07-06-16, 04:37 PM
Fivepoint0
Fivepoint0's Avatar
Try the Megan upper arm .
Old 07-06-16, 05:20 PM
bbong
bbong's Avatar
I don't see it, unless you mean the non IS-F ones?
Megan wasn't a very reputable thing in the past, not sure if much has changed, I would have to be hard pressed to purchase anything Megan branded. Though, thanks for helping
Old 07-06-16, 05:57 PM
Fivepoint0
Fivepoint0's Avatar
A few member here run the Megan arm and works fine.
Old 07-06-16, 07:18 PM
subiepunk
subiepunk's Avatar
I have the Megan arms and have put about 10k miles on them with no problems. Pat previously had these. Not sure how many miles he put on them but they held up fine. The only other company I can think of that also makes an arm similar to this is Godspeed.
Old 07-06-16, 09:08 PM
FIGS
The Maker
FIGS's Avatar
This is our solution.
http://shopfigs.com/v3/index.php?rou...=upper+bushing
and our write up.
http://figsengineering.blogspot.com/...s-f-front.html
We also make custom projects.
The nice thing is that you are also freeing up the upper arm movement vs a staked rubber bushing and a lifetime warranty bushing at that.
Mike
__________________
Redefining Lexus Aftermarket Parts Since 2001
-- We are your Lexus suspension experts--
BCR - KW - PENSKE - OHLINS - HKS - GREDDY - STANCEPARTS
Links - Arms - SuperPro Poly Bushings - Solid Bearing Conversions - Motor Mounts
RB BBK's and 2P Rotors, G-Loc pads, Radium Fuel Systems
Custom Fabrication Design and Machining - Industrial 3D Printing - Laser Cutting
2018 USTCC Sportsman Class Champions - 2018 NASA ST5 National Champions
Old 07-06-16, 09:22 PM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
I felt the same way about the Megan products but have it on my F and no problems. Many other ISF owners also have them.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Old 07-07-16, 12:11 PM
bbong
bbong's Avatar
Looks like I'll be looking closer at the Megan ones. Figs bushings are not what I'm after, though @FIGS, you should make the equivalent to what Megan did for ISF, I'd be all over it
Old 07-07-16, 05:39 PM
eternallx
eternallx's Avatar
and our write up.
Mike
^^^^ Agreed with bbong
Old 07-09-16, 06:23 PM
FIGS
The Maker
FIGS's Avatar
The pocket that the factory arm has to to fit into means that most will be a negative camber arm only. We have made uppers like I said and we continue to do so on a custom basis since there is so much mis information about exactly what you can do with an upper and what customers want. Track, camber fix, negative camber, these are all different goals with different solutions. The Megan arm is a negative camber arm only and if really pushing it will hit the inner tire well guaranteed based on the top clearance. The bushings allow on car adjustment and can easily swing from mild correction to extra grip.
This is ONE of our offerings but like I said we cut custom parts all the time so if serious we can make it. We are making 2 other IS-f custom uppers this coming week for spirited track use.
__________________
Old 07-10-16, 07:24 PM
blckbrd
blckbrd's Avatar
Damn Mike! Those are beautiful!
Old 07-13-16, 12:05 PM
bbong
bbong's Avatar
Sent PM, these look beautiful!
Quick Reply: Adjustable Front Upper Control Arm
