suspension & lowring question
pardon my noobness question but is there an ultimate or rather definative setup for lowering the vehicle and acheiving the best camber solution? ive always just done the springs/alignment route before but now i see so many products out there such as the usrs from rrr, products from figs, adjustable arms from megan etc. did a suspension search but just came up with a bunch of products but wasnt sure if they all served the same purpose? one for camber one to assist in toe-in? preparing to mod my IS-F and this time i just want to do everything right, thanks guys
Depends what you're trying to do and how much you drop, camber, wheels you're trying to run. Camber isn't adjustable on the F so most of those items will give it adjustability. Usrs helps with steering response and the toe out on braking because the bushings r much firmer than stock ones.
Perfect suspension setting for cheap.. Swift Springs and RR-Racing USRS.. Both in stock, and local to you. ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
-Josh
-Josh
__________________
![](https://www.clublexus.com/forums/signaturepics/sigpic167102_16.gif)
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Orange County, CA
skottydznt
09-16-14 08:53 AM
