Volk fitment question
Old 07-12-16, 01:48 PM
geero
geero's Avatar
Default Volk fitment question
I am close to purchasing a set of Volk LE28's and the rim sizes are as follows:
19x9.5+22 (front)
19x10+22 (rear)
can anyone help determine if these would clear our bbs?
Old 07-12-16, 02:15 PM
jspecvtec
jspecvtec's Avatar
Probably but those offsets r mighty aggressive. Either gotta run stretched tires, camber and fender mods to fit
Old 07-12-16, 02:41 PM
geero
geero's Avatar
damn, just want a clean setup
Old 07-12-16, 04:11 PM
tas02
tas02's Avatar
Those sizes will def. clear the F brakes. And they will def. be "a clean setup".
Fender clearance is the issue.
Old 07-12-16, 05:16 PM
jdmSW20
jdmSW20's Avatar
yeah with those offset you are for sure going to be running a lot of stretch and camber but it can be done
Old 07-12-16, 09:37 PM
bnizzle87
bnizzle87's Avatar
What tire sizes were you planning to go with? I have seen it work on the fronts, but the rears, as stated earlier, will be a challenge without modification of some sort. That's the downside with Volk Racing. Wheels are so nice, but offsets are killer for our cars.
Best of luck on the wheel search!
Old 07-13-16, 05:03 AM
Defratos
Defratos's Avatar
Don't Volk have these in like +32 or +35 offsets? I remember the TE37SL had these options.
Old 07-13-16, 05:08 AM
geero
geero's Avatar
think theyre discontinued
Old 07-13-16, 09:23 AM
tas02
tas02's Avatar
Search using keyword "ZE40" for PsXHuNtER's thread on making these wheel sizes work.
Old 07-13-16, 12:58 PM
Fsport2UR
Fsport2UR's Avatar
Your offset would be similar and close to this gray ISF(Nebula Gray Pearl?).
https://www.clublexus.com/forums/is-...ml#post6460193
His front + the spacer is more aggressive. But the rears are a similar flush stance offset(19x10 +22offset is near same as a 19x10.5 +30offset).
I would follow what the gray ISF has done, which is rolling and a lot of pulling.
Deathrow23
06-01-15 05:58 PM
LionelHutz
IS F (2008-2014)
12-15-13 09:25 PM
blackkarma
IS - 1st Gen (2001-2005)
07-29-13 05:51 AM
lol
Wheels, Tires & Brakes Forum
06-25-13 05:43 AM
passnu2
12-20-08 12:29 PM
Quick Reply: Volk fitment question
