ISF gets a new garage
#47
Tech Info Resource
Concrete all depends on the lift. All the industrial lifts require minimum 6" pour. If you don't specify this when your house is built, you will get 4". I was looking at cutting square holes and digging down to pour in footings for a lift. It was looking like a really big PITA. If you are OK with a 48" maximum height lift, there is a two post hydraulic unit intended for DIY use that bolts to a 4" floor - just drill, install threaded inserts and bolt the lift down when you need it, move it out of the way when you don't. http://www.maxjaxusa.com/
This is the lift I intend to install. While I have a lot of room between the bays in my garage, putting a permanent lift in place would really limit opening car doors in all three bays. The other upside is, I can put bolt holes in all three bays so the lift can go where it is needed.
#49
Lou
#51
Tech Info Resource
