anyone getting the grom vline?
Old 12-22-16, 12:39 PM
  #226
gromaudio
Vendor
gromaudio's Avatar
Make sure to update VBase part as explained here and match your gen carefully before installing:
http://gromaudio.com/software-vl1.html
It is not a part of OTA yet.
Old 12-22-16, 01:33 PM
  #227
regeenoble
regeenoble's Avatar
Thumbs up
Originally Posted by gromaudio
Click on CP icon and then 10 times on Activate CarPlay. It should bring CP back to life
Make sure you update VBase also:
I got it going again, I appreciate your guys quick response and support. I am again a happy camper. Mine seems to running smoother now as well in other regards, I was able to get Google Maps working among some other small things I noticed while not connected to CarPlay.
Again, thank you guys for your promptness in addressing my issue.
Old 12-22-16, 01:35 PM
  #228
rehr0001
rehr0001's Avatar
Here's a video to watch in all it's glory. I'd love a suggestion as to what I can try so I don't need to unplug my unit each time I turn off my car.
Old 12-22-16, 01:58 PM
  #229
gromaudio
Vendor
gromaudio's Avatar
Can you try turning on ignition only without starting the car ?
Old 12-22-16, 02:11 PM
  #230
rehr0001
rehr0001's Avatar
If I leave the car for several minutes and return, the vline will boot without needing to physically remove the power to the unit.
I just did the following (once):
Accessory power - unit booted - i turned off accessory power - waited 30 seconds - turned back on accessory power - unit booted
Then
Started car - unit booted - turned off car - waited 30 seconds - turned back on accessory power - continuous reboot
Old 12-22-16, 02:28 PM
  #231
gromaudio
Vendor
gromaudio's Avatar
Go to DashLinQ Settings->VLine Sleep Scheduler
Make sure it is off (check and uncheck to make sure).
It might confuse the system if it is on currently.
Old 12-22-16, 02:43 PM
  #232
rehr0001
rehr0001's Avatar
Go to Settings->VLine Sleep Scheduler
Theres no vline sleep scheduler that I can see. If I click into the dashlinq settings, I can't scroll vertically. In the Android settings I don't see anything about the sleep scheduler.
Old 12-22-16, 02:55 PM
  #233
rehr0001
rehr0001's Avatar
Then
Its random. I've had success and failure starting, using accessory, and all combinations. Sometimes it goes to continuous reboot, sometimes it's fine.
Old 12-22-16, 03:52 PM
  #234
johsti
johsti's Avatar
I'm having the same issue with the constant reboot, but it seems to be working now after unplugging and reconnecting all connections from the Vline unit and then doing the initial startup procedure as referenced in the manual. It does seem very finicky about when you plug your phone into the usb cable. If I plug my phone in before booting to the Grom dashboard, it will go into perpetual boot mode showing the "Vline" screen and then color bars just like the video you posted. This is on a 2005 LX470.
If the carplay icon goes grey after plugging your phone in, try rebooting your phone or going into the carplay settings on the phone and click "forget this car". Then try plugging your phone in again. This seems to work for me.
Old 12-22-16, 03:58 PM
  #235
rehr0001
rehr0001's Avatar
My reboot problem appears to be fixed now. I did a complete reset of the unit (erased all settings). Is that what yo mean by following the initial startup procedure? I'm still getting random reboots now, but haven't been stuck in a continuous loop since starting fresh.
Old 12-22-16, 04:40 PM
  #236
gromaudio
Vendor
gromaudio's Avatar
johsti rehr0001 Can you see any particular pattern when restart is occurring ? We need to simulate the scenario here.
Old 12-22-16, 05:58 PM
  #237
gromaudio
Vendor
gromaudio's Avatar
We were able to replicate the issue. The fix is coming tomorrow.
Old 12-22-16, 08:53 PM
  #238
GarageB
GarageB's Avatar
hope so. mine is stuck in boot loop.
Old 12-23-16, 01:10 PM
  #239
hypervish
hypervish's Avatar
Is it safe to update now?
Old 12-23-16, 02:28 PM
  #240
stopdrpnro
stopdrpnro's Avatar
Was thinking about returning my bt3 for the vline , but it looks like it's still a long way from being a "complete" solution.😞
Quick Reply: anyone getting the grom vline?
