anyone getting the grom vline?
#406
Grom now has the "Lexus Toyota 2010-2012 GROM VLine Infotainment System Upgrade Video Interface" for pre-ordering..
My only Major issue I have so far with ordering is the "LOW" and outdated hardware specification "Quad Core Cortex-A7 MCU 1.35GHz 1GB RAM, 16GB Flash".
For people with the latest firmware on the hardware "Lexus Toyota 2006-2009", besides the "bugs/issues" what is the performance/user experience/loading like?
Thanks
Thanks
The one issue that still kind of, almost, bugs me, is the navigation feature for Google Maps does not work if I am connected to the internet. I can use navigation feature if I am in offline mode in an area where I have downloaded the maps, but once I try to navigate while connected to the WiFi, Google maps force closes. My gut tells me it's because of the hardware specs, however, I won't go on record saying that.
I have not seen anyone else complain about it. I don't even know if anyone else has had this issue. That being said, having Waze on the nav is amazing, also, having CarPlay in my car is about as good of a simple tech upgrade as you can get, IMO.
Overall, I'm very satisfied and 10/10 would buy again, but I understand the firmware for some newer car models were still having the bootloop issue. For my unit, that was addressed in one of the December updates and I have not looked back since. Hope that helps.
#407
Upgraded... now pressing SCAN 3 times does absolutely nothing. Before at least the screen would flash like it was going to change to the audio controls, but now there's no indication that I'm pressing any buttons at all. Anybody else seeing this behaviour, or just me?
#408
V line working good since saturday. Not one crash or reboot necessary. Only issue now is getting local music to play. I imported some podcasts on to my micro sd and the v line is not recognizing the music. I installed the direct tv ap and very limited. Not easy to navigate and was able to play only a few videos. Neflix ap recognizes library but won't play vids. Youtube works perfectly. Waze with pandora is flawless. Pretty happy for week one.
#409
Anyone having problems with local music? The v line does not recognize any of the music on my micro SD card.
Also, My iPhone doesn't automatically pair up via bluetooth to factory unit. I have to do manually before I drive if i want to make phone calls through the factory system. That is the biggest annoyance so far.
The web radio is awesome though! Sound quality far superior than XM.
#410
Hi fellas,
So... I purchased this during the presale under the hopes carplay would be enabled soon although many reported it was working outside the box. Hence, I was pretty stoked. Well, long story short, finally had an opportunity to install it after traveling for work, school, family and life. All appears to be working ok yet carplay is not available... Am I missing something? Any help would be greatly appreciated and thanks y'all.
#411
Hi fellas,
#413
#414
Thanks
Thanks
It seems like Carplay is working a whole lot better than AA, for starters because AA isn't even on vline yet, but CP still has some bug issues (at least from what I've read; I'm an Android user so you'll have to ask other CP users for their verdict). If you're an Android user, I'd say stay away until they get AA baked in or a stable firmware release so you can run the HeadUnit app. I'm about to install firmware v27 so I'll post my issues later this week.
#416
Put the main box in the glove compartment as you will need easy access to it especially since you'll have to update the firmware quite often until stability is reached, if it will ever be reached. It's been ~6 months since I've had mine and it's still not stable at all so my confidence is draining.
#417
#418
Just wanted to update on things we are working now.
1. Startup times. We were able to shave off 5sec off boot time, so on average you can expect ~18-19s boot time.
Will be available through next 2 OTAs this and next week.
2. Longer sleep time. Module will be in sleep for 1-4 hours (will adjust to your schedule) to be available when you need it instantly
Will be available via VBase USB update next week.
3. Smart scheduler. Still in works. Ideally will make it available instantly every time you need VLine without battery drain.
Should be available via second OTA from #1
You will get update via email blast directly when updates are ready.
#419
Vline Carplay issues
I have had the VLine for my 06- GS450H since I believe the second week of October 2016. It has performed well and has constantly been improved. I encountered the boot loop issues in December or January but those were fixed with the most recent updates. it loads in under 30 seconds. I have loaded audio and video files on a 64 gb usb drive. I occasionally stream directly from my android phone. Google maps, web radio, pandora, and google music plugin all work fine when i use my mobile hotspot with either my S6 or Iphone6. I use the in-vehicle bluetooth for the phone connection with my android phone.
I have had an issue utilizing the carplay option with my iphone 6. I activated the carplay ui by pressing it 11 times. I plug my iphone into the usb1 port and the carplay icon briefly turns green then goes grey. When I go into phones Carplay menu it searches for a unit to connect to but never finds one. I tried a friends iphone 6 and had the same issue. Is anyone else having this issue? Does anyone have a solution?
#420
