anyone getting the grom vline?
#452
Sadly, the response I just got to the GROM support ticket (#511231) I opened on Friday was, "The hardware for the most part is the same, The wiring is different and is currently not sold separately at this time.", from Jason Burgo 4/10 @ 12:14am.
Could you verify that the harness can't be obtained separately, and/or what the exact difference in wiring is. I'm fairly handy with a soldering iron and can build my own harness if it comes down to that, though would rather not go through the extra trouble. I'm sure I'm not the only person that would like the ability to move a LEX5VL1 into a LEX6VL1 car or vice versa if the only difference is software and wiring.
#453
#454
KYLS (04-11-17)
#455
And the 4G LTE Wifi Hotspot is here:
http://gromaudio.com/store/accessori...e-g-conl1.html
Comes with the USB car charger, works with ATT and T-Mobile.
#456
I'm not sure what video are you referring as I did my install without video. If you have trouble I would recommend you get a pro install that should not take much time.
#457
Nice, I've a Grom Vline on my LX470 and love it. Definitely a must as the car stereo was getting very outdated. If you guys make a newer version, perhaps you could make the unit case smaller so it's easier for us to install together with the original audio system and not loose the glove box.
#458
My guess is that having it in a smaller form factor is highly unlikely. I'm guessing they are buying these standard boxes from China and then installing a custom Android Cyanogen ROM to it. You'll still want to install it in the glove even if it's small because the likelihood of you requiring easy access to do a hard wire pull is very high because this device is still in an adolescent beta stage. I pull the power on mine almost on a weekly basis in order to do a hard reset quicker than waiting the 10+ seconds for the power to drain from it. You may also need easy access to the ports (USB, SD and HDMI).
#459
Any chance that "pretty soon" = less than 2 months? Might there be a need for beta testers for the pre-production model within that time period? If so, keep me in mind. Hopefully there is no plan to change the cables, so it is just a mater of unplugging the current VL main unit and swapping in this new one. Exciting news, thanks for sharing.
KYLS (04-13-17)
#460
I have installed VLine and now my stock navigation is a blinking white screen. Same for reverse camera. Everything else (including VLine) works. Any ideas on what might have gone wrong?
#461
I installed it in my 2009 IS350 and even though I had issues routing the cables from behind the radio to the glove box I was able to do it. You'll have to loosen your glove box a bit (there are three screws along the top of the glove box), then stick your hand as far as possible behind the stereo and as far as possible in the glove box. Then you pass the cable from the glove box you'll feel the tip of the cable in the compartment behind the stereo.
Good Luck!
Good Luck!
#463
Anybody else with a Grom Vline having issues with Waze app? I have a Grom vline in a 07 LS460. Google maps works fine but I cannot connect to Waze. It is stuck on "searching network".. Thanks.
#464
![Angry](https://www.clublexus.com/forums/images/icons/icon8.gif)
Has anyone experienced the vline getting very hot? Mine has shut down twice now after an hour of use due (during long trips). To get the vline to start working again I'd have to restart the car. On both times it crashed recently, the box was very hot (I placed the vline box in the glove box for easy access). Has anyone else experienced this overheating issues? Has anyone had their vline crash due to overheating?
#465
I have had to uninstall and reinstall Waze a few times for various reasons and it has come back working perfectly every time. One time, I force closed it when it could not connect to the network after repeatedly opening and closing the app. After the force close it would not open at all. After the uninstall/reinstall it worked instantly. Hope that works.
