anyone getting the grom vline?
#557
1) Install V-Line
2) Settings --> About --> Update to Latest Software
3) Settings --> About --> Enable GApps
4) Repeat #2 if needed
5) You should now have a working Google Play App.
6) Install Waze
7) Click on the settings icon for the launcher to set the app for Navigation - this will enable the "arrow icon" to take you to Waze... (so I think)
#559
I don't have this option either, but I haven't installed an SD Card yet. Do you have on installed?
#561
So I installed a new MicroSD card and it seems that I now have a download option available but...
When I try and save a map area I am unable to do a pinch/zoom/drag to select the map area that I want to save. In fact there is no working pinch and zoom feature on the display. This is very disappointing since the whole point of having a touch screen is to avoid having a mouse. Actually I don't even know if a mouse would help as I haven't tried one.
#562
#564
aight, so finally pulled the thumb out my *** and installed this ( bought it on the releasesale ) the installation was straight forward, mounted in the glovebox, BUT I have a major problem, all works except for the volume, at MAX it plays like its on maybe vol 20.. cant adjust anywere, also the soundquality is worse than a boombox from the 70s.
anyone had this problem?
#565
#568
And you've turned up the volume on both your phone and the GROM system?
I've had issues with my volume as well. It will fluctuate for no reason and the GROM system will randomly attenuate the media volume so I have to go back into settings to adjust to max. It's really odd and buggy. This is after numerous factory wipes of the GROM system after each major update they've rolled out.
#569
I was using the "Local Music" app to play music off my USB stick and then switched to the FM radio to listen to a news station. When I switched back the Vline unit would not output any sound at all. This unit is really starting to disappoint. Tried turning the power on and off a few times and still nothing.
I also notice that when using the "Local App" there is now way to adjust the fader/balance or the DSP audio settings. There is the built in equaliser feature but no fader or balance control. Another disappointment.
#570
http://gromaudio.com/support/vl1-faq.html
Functionality->How can I adjust fader/balance ?
