anyone getting the grom vline?
#706
The only wishlist for the Local Music player is to be able to save shuffle random songs instead of playing song sequence by default.
WillAP1 (11-27-17)
#707
Ok, I'll try just the memory card with no USB next time I drive the car. Winter's coming and it only get duty if it's really nice a dry out. Sometimes only once in two or three weeks.
BTW, has anyone else noticed some distortion with some music when using the Poweramp app as their music player. I am not sure if the distortion is due to the app, the mp3 compression (320 Bit rate), FLAC compression (I have a mix of both types) or if it is the Vline unit. I only hear distortion sometimes on a few different songs, All of my music is ripped from my own CD's so the source was good, I just don't know if it is the ripping software I used or if it is the app. One of these days I will have to note down when I hear the distortion and then try and listen to the same files on another player. Interested to know if any one else has had any similar experience.
#709
MY Vline problems.
No reverse camera
bluetooth connects 50% the time
When bluetooth connects 50% chance no app sounds, gets system sounds though.
20% time screen is black.
Bluetooth often drops.
No reverse camera
#710
In the future, It would be nice if GROM could pre-test iOS updates and inform customers beforehand if CarPlay is going to break, since it is not possible to downgrade the iOS once applied. The BT work-around is better than nothing, but a step backwards. Hopefully you can understand your customers are frustrated after a promise of a fix, then a long wait, and now more delay to see if Apple will fix it in an update. I would have stuck with iOS 10 had I known in advance of the problem.
#713
Mine is working perfectly with reverse and touch screen.. but I got internal a file from grom that updates the "VBase"... The 100+mb only update the "Vcore" 2.1.0.0 -> VL3.3.0.0.
#714
Waiting for VL2 release date to avoid having to upgrade...was going to pull the trigger today and luckily I have not updated to iOS 10.
#715
We have fixed all the issues. Make sure to update both loader and Android via OTA. I suggest updating OTA to 3.3.1 first, then it will prompt you to update loader firmware either via OTA or Flash drive depending on firmware you have.
#716
Isn’t the 11.2 beta update already available to developers? Have you verified if that contains a fix for the GROM CarPlay issue?
#717
We will start production before the NY. Around Dec-20. There will be announce around that time. If everything goes well, it will be ready by end of Jan.
#720
LOL, that’s rich. You mean CarPlay isn’t an advertised feature ANYMORE. It most certainly was advertised when I bought my unit. Don’t try and use that cop out.
