We have fixed all the issues. Make sure to update both loader and Android via OTA. I suggest updating OTA to 3.3.1 first, then it will prompt you to update loader firmware either via OTA or Flash drive depending on firmware you have.
Sorry to say but I updated and the touchscreen still goes unresponsive after I change out of Reverse Gear..
What version of VBase firmware you're running ? In some casers it needs to be updated via Flash drive. Update page should tell you so if it detects older versions.
I have whatever the current OTA is, if there is a way to fix this please advise what I need to do
For the last two days my vline has been doing nothing but being stuck on the vline screen. Not sure what to do. I just keep getting more and more disappointed with this thing
Im getting the same problem. Sound quality got really bad for me. So bad that i’m Using the factory Bluetooth to play my music.
Send our support a note on it. Specify firmware you're running, your car make/model/year, They can send you special firmware with adjusted gain to check which values are good for your car.
