anyone getting the grom vline?
#1201
If you bought a VL2 expecting it to be perfect despite knowing how things were/are with the VL1 then you were destined for disappointment. Was pretty much guaranteed there were going to be initial issues with the VL2 that you'd have to work through. Other than the guy's who got bricked it doesn't even sound that bad. Still far from ideal, but again, you should have known what you were getting into.
With that said, I'm pretty happy with my VL1 at this point. Drove ~400 miles today using Waze for navi and Poweramp to listen to music simultaneously (and Car Launcher AGAMA as my launcher). Only issues I had were Waze crashed once (probably not VL1s fault) and GPS disconnected for 10-15 seconds a few times (I have it in the glovebox so probably not the VL1s fault either). Overall leaps and bounds better than when I had to drive the car a similar distance with the OEM navi/stereo.
After VL2 is on the new version of Android and most/all the major bugs are worked out I might consider upgrading but honestly it doesnt look that much faster than my VL1. Maybe I will make a video to compare speed.
#1202
My reverse camera works with no issues. I'm not sure what the connector is for but when I took my head unit out, everything was plugged in as it should be.
If you are able to look behind the unit you will probably see where it needs to be plugged in.
For the installation, only two plugs are affected. Make sure you pulled the right white plug.
The GROM installation videos point out the right locations for each plug.
Those with VL2, does your reverse camera work? Mine doesn't, occasionally goes to black/white bars or just black for a couple seconds then comes up with the park assist proximity screen.
Also, anyone know what this connects to? Could not find anywhere to plug this back into when I was installing the Vline and began unplugging stuff on the nav.
#1203
#1204
https://www.youtube.com/watch?v=LCnfrmzYLmQ
#1205
As I look closer at the plug and you mentioned FM stopped working, it looks like the plug for the antenna.
#1206
I tried to follow this video but the back of my nav is a bit different from the one in the video ( i have a 2011 ISF, Australia). The MCFLEX6 cable is where i have problems - mine are both male, not male/female like in the video. Therefore I thought logical thing is to replace both OEM male plugs. I had no issues with the GVMF cable, it was same as the video male/female.
#1207
@badbwoy007
nice videos.. does it auto-dim?
Can you press a button on the steering wheel to open up Siri or OkGoogle?
#1209
#1210
#1212
Please make sure to check your inbox. We have sent email to you with recovery procedure. OTA with GApps fixes will be out tomorrow.
#1213
On day 1 I connected to my iPhone with no problem, but 45 minutes into my road trip after a crash, it would no longer connect (network wasn’t visible). When I got to my destination where there was 2.4 GHz WiFi, the Grom wouldn’t recognize it (or my hotspot). Now that I’m back at home, I noticed it sees all of my 5GHz networks, but not the 2.4. So my question: is this a hardware or software problem?
#1214
This is what I get for a couple seconds when reversing. After that it goes to park assist display. I'm using the vline2 with car launcher agama as its so much more intuitive. Could that be an issue. Reverse cam doesnt work in default dashlinq either though.
Any tips?
Any tips?
#1215
https://youtu.be/ts5N4CG85K8 these go for 390 and are made for every model of Lexus. If you buy them directly from the company, Cosmo sells them way cheaper than buying them from AliExpress, which sellers are pushing them for over 500... I emailed him a month back prior the the VL2 launching and i figured i'd give grom a chance with the launch of the VL2.
Sad to say, Grom is marketing a "finished unit" which anyone can clearly see, it is far from ready for primetime, let alone the finished price of 500.
Grom is NOT the only company that offers an Android unit
When Grom can actually offer what they are "marketing", it's going to be a great product.
I was truly hoping that when Grom started advertising the VL2, I figured they had finally fixed the issues that riddled the VL1, but it looks like nothing has changed.
